need to show client shots: how to connect EX-1 to tv?
Hi there,
Can someone tell me if I need to carry any special cable or adapter or whatnot... I'm shooting something on Friday and my client wants me to connect to an lcd tv and show him the footage. thanks, Malcolm |
If the TV is no more than a couple of years old there's a good chance it would have an HDMI input, if not it would have a component input, at the very least a composite input. RCA or S.
Hook it up, select the proper input using the menu of the TV get the popcorn and watch away. This is all assuming of course that the TV is a flat panel, LCD or Plasma and current technology. If it's an older set it may only have RCA or S video input but the process is the same. HTHs
What do I know? I'm just a video-O-grafer. Don |
thanks Dan,
One of those options will work, I'm sure. I appreciate the help. Malcolm |
If it's an LCD TV it most likely has a component in. Use the component cable that came with your EX1 and have an 1/8" to RCA cable for sound coming out of the headphone jack on the EX1. The EX1 doesn't have an HDMI out so you won't be able to use HDMI into the TV. If you've got an EX1-R you could use teh HDMI.
I always carry a BNC to BNC coax cable to hook up to a monitor for the director. If you've got that I'd also get a BNC (female) to RCA (Male) adapter. Almost all TV's still have a composite RCA input. Garrett |
#5 |
thanks Garrett... I'll add the BNC cable to my kit too.
Malcolm |
#6 | |
SDI BNC to RCA?
TIA, Rob |
#7 | |
But to get the best quality out to a TV I'd use the supplied component cable and connect directly into the component in of the TV. That's even cheaper, Sony gives you that cable. Garrett |
#8 |
How to connect EX-3 to tv - no signal on camera monitor out
I am able to connect a LCD with a antenna in to the ex-3 with coax. Got that done. Don't seem to get any signal from the camera... not sure if the output needs to be on a set for channel on the TV (Tried every thing on it but nothing). Maybe it doesn't work. How to test?
Tried the monitor on an output from a satellite converter, worked fine on Ch 3. I am stumped as to what to try next. I'd try composite but I bought the gear used and didn't get the Sony cord. Any ideas there? Monitor has hdmi vga Y Pb Py CVBS and "TV" bnc connector inputs to choose from. Or, what will work, could use a laptop or iPad which we have but trying to not buy a real field monitor. Long story why we didn't do that on this first round... but that may be the only solution. Whatever help anyone can offer will be really welcome since I've got to use this next week with a client. |
#9 |
Re: need to show client shots: how to connect EX-1 to tv?
Assume you want to connect the Sony EX1 to the HDTV with component input (for view HD LIVE or clips).
You need the component cable which came with the Sony EX1 camera. One end of the cable with special connector which plug into component out of the EX1. Other end with 3 cables with male connectors: RED - BLUE - GREEN which you will connect to HDTV component input as: RED cable to Pr / BLUE cable to Pb / GREEN cable to Y (Video) without the need of BNC adapters. |
