XDCAM EX Firmware Updates Available - Page 4 at DVinfo.net
Old March 9th, 2010, 04:17 AM   #46
Trouble conncting PMW EX1
I have downloaded and uzipped the files.
The first step in conncting the camera by USB fails
I can connect the camera by usb to transfer files via clip browser.
Is there another driver I need to install?
I presume when connected I switch on the camera and not media. Help please.
I am using windows 7.
Greg Hawkes is offline   Reply With Quote
Old March 9th, 2010, 04:30 AM   #47
Overcrank possible with SD cards !
I confirm : after updating to the new firmware my ooooooold EX1, I can now shot overcranking using E-LCR with 32 GB sandisk SDHC ! And no more errors when formatting the cards or during the cam switch-on. And yes, at the end of one shot on SDHC, the writing time seems to be shortest.
A real update !!!
I don't note other issues with this new firmware...
Enjoy it !
W.
William Japhet is offline   Reply With Quote
Old March 9th, 2010, 06:21 AM   #48
Which camera USB port did you use? My guess is you are using the media port. The upgrade port is the one under the little plate you remove by taking out the little screw. (Emphasis on little for both parts.)
Yes, you turn the camera on by setting the switch to the left. (But it might also work on media setting. Don't know, never tried and the instructions don't say.)
Pete
Clark Peters is offline   Reply With Quote
Old March 9th, 2010, 06:38 AM   #49
Thanks Clark
Yes I was using the media port.
Have located the update port and updating as I write,
Old March 9th, 2010, 07:07 AM   #50
How long should the EX1 update take? I don't want to have a panic attack at 5 minutes if it takes 10. :)
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old March 9th, 2010, 07:16 AM   #51
About 15 minutes
Old March 9th, 2010, 07:21 AM   #52
MxR after the update?
Did anyone try yet on the PMW-EX1 to see whether the MxR adapter still works after the firmware update?
I saw several using the EX3 and MxM reported no issue on this matter, but what about the EX1 and the MxR adapters?
Thanks in advance.
Armando.
Armando Accardo is offline   Reply With Quote
Old March 9th, 2010, 07:28 AM   #53
No trouble, but I did loose 2 mins of record time on both my SxS and KxS-Transcend cards.
I have a EX3 and does anyone else on this board, has this happen to them?
Bill Griffin
SONY PXW-X320,PMW-300K2, LiveU LU-500,Sound Devices 552 Mixer,www.Dallascamguy.com
William Griffin is offline   Reply With Quote
Old March 9th, 2010, 07:31 AM   #54
EX1 also 2 minutes per card lost.
Can anybody provide a link for the Ex3 firmware upgrade as the Sony site does not seem to respond using Google Chrome?
Old March 9th, 2010, 07:49 AM   #55
Greg,
are you seeing this using the adapters (like MxR, MxM) or with the original SxS cards?
About the link I get this one from my browser:
http://supportdocs.sonybiz.net/sf/0/3/G/C/SS03GC_1.ZIP
Armando.
Old March 9th, 2010, 08:14 AM   #56
Armando
Thanks for your reply.
I use S X S and Sansa SDHC with the Kingston adaptor if I need extra recording time.
I have two EX1 which I have just upgraded the firmware.
A friend of mine has two Ex3s and that is why I asked for the link.
Old March 9th, 2010, 08:15 AM   #57
This certainly sounds like a firmware bug - why loose 2 mins, even with the original SxS?!!
Old March 9th, 2010, 08:22 AM   #58
Originally Posted by Greg Hawkes View Post
Armando
Thanks for the info you have provided.
I have couple of MxR adapters and wanted to make sure they will still be supported after the firmware update.
Old March 9th, 2010, 09:06 AM   #59
This thread is a MESS to follow. People are reporting record time changes and S&Q changes without posting all the details.
How about listing ALL the following in you posts:
Camera upgraded: EX1, EX3, EX1r, 350
Features gained or lost with Adaptor (LIST Adaptor) and/or SxS card.
None card related features gained or lost.
Changes in Menu specifically.
Old March 9th, 2010, 09:24 AM   #60
I reported overcrank 60p in 720/25P recording mode with Kensington/Transcend 16gB class 6.
Unfortunately it was just with the first combination it worked with no limits. My other Transcend cards are not able to overcrank to 60p in more than about 20 - 30 seconds.
EX3 - 1.1
Bo Skelmose is offline   Reply
