#16 |
The reason I need to consider the mxf is that PPro will not display the clip names from footage in the PP clip bin. When I have 50 clips, I only see 50 file names and it becomes a guessing game as to what is on a clip. When I use mxf for nle in the download, I can name every clip. Much easier to edit that way.
Now I have an mxf file on the hard drive. Why is this a bad thing? If it has the same picture quality as any other form of storage, what is the difference? |
#17 |
No one has said the MXF file is a bad thing. What Doug was saying is that you should always keep the original file in tact - even if it is just for a backup. Who knows, in the future Sony may bring out some software that will only see the native EX files. Best to be safe.
Eyes are a deaf man’s ears. Ears are a blind man’s eyes |
#18 |
To significantly improve editing with PP, I need mxf.
At best, what I could do is make one copy to my primary edit HD in mxf and a second backup to secondary HD in native EX I'd like to hear of more reasons other than maybe sometime in the future I might need something for Sony... |
#19 |
Vortex Media
In my workflow for FCP, I use Clip Browser to make copies onto two different hard drives of every BPAV folder. Those are put away offline from the rest of my NLE.
Then I use XDCAM Transfer to import just the clips and sub clips that I need for my edit. The software automatically re-wraps those clipse as MOV files during the import. At the end of my edit, I use FCP's Media Manager function to backup all of my project files including the MOV files that made it into the final edit. Its simple. It's not rocket science.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
#20 |
So you are using 3 hard drives, not 2? You never touch the first 2 archive drives and only use a 3rd drive for loading your clips?
#21 |
Vortex Media
Actually, five.
Two cheap USB hard drives that are only used for archives before anything else is done. One dual link eSata drive for actual editing the MOV files. When the project is done, all the project files (video, music, graphics, animations, etc) are transferred to two more cheap USB drives for for final archiving. Then the eSata drive is erased to make room for more projects. At any given time there may be 3 - 6 projects on the eSata drive. At the end, I have two backups of all my raw footage, and two backups of my finished project. That is the the level of risk that I am willing to accept. Soon I will be changing my workflow to use XDCAM optical discs instead of USB drives for all my archives. At that time, I'll only make single backups of raw footage and the finished project. XDCAM discs are much more reliable that hard drives.
#22 | ||
You say Quote:
As for hard drives,they are cheap enough now, certainly a lot cheaper than tapes. I too am looking into XDCAM optical discs.
#23 |
vincent
I do make 2 copies of everything, always have from the beginning. You mention clip browser preview. that's nice, but have you used premiere pro? in the clip bin of premiere all you get are file names. try editing a project with 50 or 100 clips and all you can do is guess at which clip is which! that is the whole reason for this. it is a problem with premiere but i'm not switching platforms, I'm looking at a reasonable workaround. thanks |
#24 | |
There is no need to switch platform, a Windows machine will do everything that a Mac will do and vice versa - they are both dumb number crunchers. Your skills as a film maker will make the difference not the computer. Amendment: Only just noticed that you are using a Macbook, not that it makes any difference to the advice given. Maybe you should also try XDCAM Transfer
Eyes are a deaf man’s ears. Ears are a blind man’s eyes Last edited by Vincent Oliver; February 28th, 2010 at 08:31 AM. |
#25 |
Vortex Media
Don't bother trying XDCAM Transfer because it won't work unless the latest version of FCP is also installed. XDCAM Transfer does not stand alone.
As I said before, I've never used Premiere, or even seen it running, but why can't you use Adobe Bridge to preview your clips? Even though I edit with Final Cut Pro, I couldn't imagine getting any work done in a timely manner without having Adobe Bridge running at the same time. I don't know about Premiere, but with FCP, I can drag cligs straight from the Bridge window and onto my FCP timeline or bin. You must have Bridge because it's free with other Adobe software. Anyone who has Photoshop has it. The only reason it might not work for you is if Bridge on my computer is getting codec settings from FCP like XDCAM Transfer does. I have no way of testing that because FCP is already on all my Macs.
#26 |
Doug, I have seen you mention Adobe Bridge on another post, I have just tried it on CS4 and I can't see any previews for EX files straight from the BPAV folders. Maybe I am missing something.
Premiere will import EX files directly into a Premiere Bin, and better still it lists all the files within a single BPAV folder, just drag them straight onto the timeline. However, as Ed points out they only appear as a list of file numbers, without previews. So far I can only preview clips in Clip Browser. Maybe if I re-wrap the files then I will see a preview, but I prefer to keep the data as is until it's time to output an end product.
#27 |
I use Premiere CS4 and an EX1, and I just checked something: you can easily rename the native MP4 clips within Premiere's bin/Project window. Just right click and rename.
I just tested something else: in Clip Browser, I used "Batch Edit Clip Properties" and created a name in "Title 1". In Premiere's Media Browser, it still shows the original clip name, BUT once I import it into the project window, it shows the name I created. Just an FYI, Premiere CS4 on Mac actually has fewer effects than the PC version. |
#28 | |
Vortex Media
I can see now why Bridge wouldn't be of much help for editing with Premiere. Forget I ever mentioned it. Oh well, that's just one more reason for everyone to move to FCP. :-) Doug
#29 |
Never mind Doug, tomorrow is the start of another week.
Would love to run Final Cut Pro, but my old Macs are passed their sell by date (pair of G3s) and I am not tempted to kit myself out with new computers just to run another interface (applications and OS). Although I do have a very old version of FCP installed on one of the Macs, but with 500mb of RAM installed and a 40gb hard drive I don't think I can do much with it.
#30 |
Vincent, in Premiere, you can preview the native XDCAM clips in the 'Source' window; either from Media Browser or Project/Bin. Plus, you can do what I said in my prior post about naming them.
