PAL EX XDCAM is 4:1:1 or 4:2:0?? at DVinfo.net
Old February 17th, 2010, 11:35 AM   #1
Hi,
Pal dvcam is 4:2:0.
What about Pal xdcam?
Giannis Pass is offline   Reply With Quote
Old February 17th, 2010, 11:37 AM   #2
Originally Posted by Giannis Pass View Post
Hi,
Pal dvcam is 4:2:0.
4:2:0 sadly.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old February 17th, 2010, 12:41 PM   #3
Very sad indeed :)
Bram Corstjens is offline   Reply With Quote
Old February 17th, 2010, 12:57 PM   #4
Thanks for the reply.
Old February 17th, 2010, 02:20 PM   #5
all XDCAM 35 Mbps (EX and disc-based) is 4:2:0.
4:1:1 was never used before or since NTSC DV as far as I know.
TimK
Kolb Productions
Tim Kolb is offline   Reply With Quote
Old February 17th, 2010, 03:41 PM   #6
The camera can output 4.2.2 through the SDI port.
Sony has a video online where video compression is explained and they show examples of each and 4.2.0 looks much better than 4.1.1 so imo 4.2.0 is a good thing! That's why 4.1.1 is not used for anything but SD DV.
Actually 4.4.4, 4.2.0, etc. technically only applies to standard definition video, this number scheme is just one of the artifacts left over from the early days of digital SD but everyone uses it.
Kevin Spahr is offline   Reply With Quote
Old February 17th, 2010, 06:31 PM   #7
It describes the different types of chroma subsampling regardless of definition.
Adam Stanislav is offline   Reply With Quote
Old February 17th, 2010, 08:04 PM   #8
It is actually referring to the sampling rate of the circuit for each of the components.
A number such as "4.4.4" was based on an image of 720x480 pixels using a sampling circuit of 13.5Mhz, a "2" would refer to a 6.75Mhz sampling circuit, etc.
Since full HD is 1920x1080 pixels you can't sample that at 13.5Mhz you need a much higher sampling frequency - 74.25Mhz.
YES, everyone uses the "4.4.4" numbers for HD but very few could explain the math that generates those numbers, because if they did they would understand how TECHNICALLY it is wrong when talking about anything but a SD sampling rate.
Old February 17th, 2010, 08:27 PM   #9
I don't think 4:1:1 is any better than 4:2:0.
Michael Maier is offline   Reply With Quote
Old February 17th, 2010, 09:03 PM   #10
True enough.
I've talked with industry guys who have proposed scaling the nomenclature from 4:2:2 to 22:11:11 to maintain the original math.
I guess that must've seemed too complicated
TimK
Kolb Productions
Old February 17th, 2010, 09:32 PM   #11
We never guess, we always look it up.
The subsampling scheme is commonly expressed as a three part ratio J:a:b (e.g. 4:2:2), that describe the number of luminance and chrominance samples in a conceptual region that is J pixels wide, and 2 pixels high. The parts are (in their respective order):
J horizontal sampling reference (width of the conceptual region). Usually, 4.
a number of chrominance samples (Cr, Cb) in the first row of J pixels.
b number of (additional) chrominance samples (Cr, Cb) in the second row of J pixels.
Note that this is abstract geometry and has NOTHING to do with the actual pixel dimensions ("resolution") of the video frame.
You could look it up instead of arguing about it here.
Chroma subsampling - Wikipedia, the free encyclopedia
Richard Crowley is offline   Reply With Quote
Old February 17th, 2010, 10:00 PM   #12
No one is arguing, Kevin was simply pointing out the origin of 4:4:4, in which he is totally correct. You guys have simply misunderstood him.
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old February 18th, 2010, 02:07 AM   #13
I'd have to agree. In fact, I'd rather key 4:2:0.
TimK
Kolb Productions
Old February 18th, 2010, 12:45 PM   #14
Originally Posted by Richard Crowley View Post
..........the number of luminance and chrominance samples in a conceptual region that is J pixels wide, and 2 pixels high.
You have to look back to the origins of digital video to see how the terminology came about. Initially the composite signal was digitised, and it made sense to lock the sampling frequency to subcarrier - frequencies of 3x sub-carr freq for PAL (13.29MHz) and 4x sub-carr freq (14.32Mhz) for NTSC became the norm.
Move to component, and the desire was to use similar frequencies for digitising the component signals. It was further desired to use the same frequency for the 525 and 625 line systems (which it now becomes wrong to call "PAL" and "NTSC") and 13.5 MHz was settled on as a common compromise.
The "4" and "2" in 4:2:2 etc therefore comes from "no of samples in a cycle of NTSC subcarrier", even though by the time it was first used the move from 14.32MHz to 13.5MHz sampling meant it was referring to longer than a cycle anyway.
That's the origins - the wikipedia definition is how it's now come to used, and it must be one of the worst and most confusing bits of nomenclature in the TV world. All too often it's heard that "X is 4:2:2, so it must be better than Y which is only 4:2:0". That's only true if the luminance aspects of both systems are the same, compare a 4:2:0 full raster system with a 4:2:2 subsampled one and it's completely untrue.
David Heath is offline   Reply
