12v power connector polarity
Anyone know what the polarity of the power connector is on an EX1/3?
B-Scene Films |
usually it is written on the power supply
The outer shell is negative, pin is positive.
Check it with a meter from the AC supply. I remember, as if it was a strange choice from SONY. I'm not sure....
#5 |
Contributor
Kevin is correct. The inner pin is plus.
HTH
Alex Dolgin Dolgin Engineering Camera DC Power accessories, Fast 4 position Battery Charger http://www.dolgin.net |
#6 |
almost certain that pin is minus and shell is positive - i'll check
Grabbed this : The EXDC1 4 Pin XLR to DC Adaptor is sold as a "stand alone" product and is simply a "pass through" that meets the polarity standards of the Sony XDCAM EX cameras when used with industry standard 4 Pin XLR power configurations. Due to the fact that this cable is a “pass through” with no voltage regulation, it is the user’s responsibility, when using the EXDC1, to ensure that power sources meet both the polarity and voltage requirements of their camera or equipment. (EXDC1 Specs Pin 4 to Shell, Pin 1 to Tip) 4pin XLR are are pin 1 minus and pin 4 positive !!!!!!!!!!!!!! http://www.filmwareproducts.com/Vort.../VM-EXDC1.html |
#7 |
Bo,
Your information is wrong. While XLR 4 pin is pin 1=negative and pin 4=positive, on the camera side, center pin is positive, outer shell is negative. I just confirmed this by using a voltmeter on the output. Sony does have a non-standard dc connector, by that they mean it's SHAPE and size is non-standard, not the polarity. Just to be clear to not confuse anyone, center pin is positive, outer shell is negative. |
#8 |
Great - you have to be 100 % sure before you connect - so now there should not be any problem with this :-)
Sorry to have confused you. |
#9 |
Always check polarity with a multi meter. This is not something you want to make the wrong decision on. The results could be a disaster.
Paul Hudson Lizardlandvideo.com Phoenix video production |
#10 |
Centre pin is definitely positive, i've just made a lead to power my EX1 from the top stage of my Pilot.
The lead has been used a coulpe of times, nothing blew up. Centre pin is +. Paul.
Round 2 GH5,FZ2000 |
#11 |
Confirmed.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#12 |
Yes, center pin is positive (+).
#13 |
I have made several power cords for my EX1 and I can confirm that center pin is positive and outer shell is negative. And the industry-standard 4-pin XLR wiring is 1=negative, and 4-positive with no connection to pin 2 or 3. I actually found one of the RadioShack modular power connectors that fits the my EX1 perfectly.
I once made the mistake of wiring a power cable reversed and plugged in one of my Sony DXC-3000 cameras. Surprisingly, the only casualty was the three op-amp ICs in the Fujinon lens servo circuitry. The main camera body was protected against reverse voltage by the internal DC-DC converter power supply module. The camera circuitry doesn't actually run directly from the nominal 12V coming in from the outside. I also have a DSR-300 and the service manual shows that it has a similar power-handling scheme. NOTE, however, that the current models may very well have very different power handling schemes than those older models. I don't have any knowledge of the EX1 internals and I would assume that feeding it reverse polarity would FRY it to crispy, smoking cinders. |
#14 |
Thanks, gents. Built my cable last night. Works like a champ.
B-Scene Films |
