Ex1r Pal is Upper field?? at DVinfo.net
Old February 15th, 2010, 01:10 AM   #1
Hello,
I have shot a wedding with my Ex1r at DvCam50SQ resolution and i export a QTRef file from Avid MC4.0.3.
Then i import the file at TMPEGEnc. At the first transcoding procedure i have lower field, but at the end i have interlaced problems.
Then i do the same but with Upper field and everything was ok.
Is it right?
Pal DVcam is Upper field or it is because of the Xdcam?
Giannis Pass is offline   Reply With Quote
Old February 15th, 2010, 08:55 PM   #2
Contributor
Giannis - you need to determine where in the chain your field order is getting reversed. I've responded to another post like this from you. Did you check inside the Avid interface using the technique I described to find out if your field order is correct there?
Other things to check: are you exporting as a QT ref or full QT? If it is a full QT what codec are you using? Many PAL codecs are upper field first.
John Mitchell is offline   Reply
