EX1R and Avid! Help..... at DVinfo.net
Old January 31st, 2010, 11:21 AM   #1
Hello,
i want to import Dv files that shot with ex1r to Avid Media Composer.
It is .AVI files.
I have to use File Browsing or import directly to Avid from the card?
What settings to Avid import?
Giannis Pass is offline   Reply With Quote
Old January 31st, 2010, 02:52 PM   #2
The import settings will have no effect, if you are importing files then they will be native DV. If you digitise then you can change the format.
The only way to import with Avid is with the Import menu or drag and drop into the bin. Are you on Mac or PC?
Roddy Jamieson
Roddy Jamieson is offline   Reply With Quote
Old January 31st, 2010, 05:38 PM   #3
Originally Posted by Giannis Pass View Post
Hello,
It is .AVI files.
The latest version of Avid Media Composer - version 4.05 - now supports this directly through AMA.
Here's what is written in the readme file for it:
* Avid supports linking to XDCAM EX DV-AVI media, as well as 1440 x 1080 HD media
with AMA. Go to http:/www.avid.com/ama/ to view the XDCAM EX AMA Plug-ins
Release Notes from Sony.
Steve Gibbons is offline   Reply With Quote
Old February 1st, 2010, 05:00 AM   #4
Telecam Films
AMA is awesome. I did some tests yesterday with mixing PAL and NTSC 1080 60i HQ and 1080 25p HDV footage shot with the PMW350 on the same card. I could edit straight from the SxS card and mix the clips at will on the timeline. All played back smoothly and in real time. Pretty amazing...
T.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old February 1st, 2010, 09:32 AM   #5
Using AMA is the same procedure with DV and with HD 1080??
What procedure i have to follow, to import with AMA?
Old February 1st, 2010, 12:57 PM   #6
Telecam Films
Which version of Media Composer do you use?
Thierry Humeau, DoP
Télécam Films
Old February 1st, 2010, 01:08 PM   #7
I am using 4.0.3
Old February 1st, 2010, 01:19 PM   #8
AMA should link up to any P2 or virtual P2, or XDCAM/XDCamEX volume. It can't do that with any tape based format.
Old February 1st, 2010, 03:30 PM   #9
Make sure that the AMA is activated in Settings (first on the list). Then whenever an XDCAM disc or SxS is detected, it fills a bin with it's contents.
I used with the XDCAM discs, but found it to be slow, the SxS should be much faster.
Roddy Jamieson
Old February 11th, 2010, 09:58 AM   #10
The AMA is working only with HiDef XDCAM files, or also with Dvcam?
I am asking it because i cant find any files recorded to Dvcam format
Old February 11th, 2010, 10:54 AM   #11
DVCam is tape. AMA does not work with tape.
Old February 11th, 2010, 10:57 AM   #12
I think you mean that you can't find any DV footage. I assume you had changed the recording format before shooting?
Roddy Jamieson
Old February 12th, 2010, 05:46 PM   #13
I have ex1r and i have recorded dvcam footage.
My question is if i can use AMA with dv or only with HD.
Old February 12th, 2010, 06:17 PM   #14
AMA does not understand DVCam. It understands XDCam, P2, and one Ikegami type.
Old February 13th, 2010, 05:32 PM   #15
Perrone - I'm sorry but you are wrong about this. The answer given earlier in this thread is correct.
Avid Media Composer does in fact recognize DVCAM (yes - this is what Sony calls even the non tape based version of the format) as AMA media. You have to use ver. 4.05 for this to work though.
Ola Christoffersson, Kamrat produktion, Stockholm - Sweden
www.kamrat.tv
Ola Christoffersson is offline   Reply
