How to send digital signal from EX1 to DV firewire at DVinfo.net
Old January 24th, 2010, 07:06 AM   #1
I tried to send from firewire to dvd recorder but it does not understand the signal.
There is box that can change SDI to firewire dv but it costs 1500€...is there some cheaper and simplier way to do this?
Christian Valtanen is offline   Reply With Quote
Old January 24th, 2010, 08:47 AM   #2
Camera sends video out firewire only when in SP (HDV Compatible) mode. If you shoot in HQ (XDCAM EX) as you should, it does not output firewire. It outputs HD-SDI. Blackmagic has a bunch of converters but none to firewire.
Blackmagic Design: Mini Converters
They do have SDI to Analog which might give you a way to connect to a DVD Recorder.
Old January 24th, 2010, 11:07 AM   #3
I don't know if the EX1 will do this but the EX1R will send standard def down the firewire on media playback. I was able to record footage shot at 1080 24p via firewire to my consumer sony mini dv camcorder which looked great. When I tried the same thing to my Panasonic DVD recorder it didn't work out; the recorder got confused every time I manipulated the thumbnails in the camera. This is not a simple process but playing back in camera and recording to dv and then recording mini dv to dvd recording is certainly cheap and should be fairly lossless in quality via firewire. The downside is it is quite time consuming.
mb
Mark Bolding is offline   Reply With Quote
Old January 24th, 2010, 10:37 PM   #4
EX1 is ONLY HDV over firewire.
Old January 25th, 2010, 02:13 AM   #5
other solution?
or have you seen dvd recorder that can take hdv in?
Old January 25th, 2010, 09:25 PM   #6
Hey Craig, your caps lock button is stuck
Old January 25th, 2010, 09:27 PM   #7
I have a finger STUCK to the CAPS LOCK key. I'm not going to tell you which FINGER though. <wink>
Craig Seeman is offline   Reply
