Tiffen T1 filter on all the time? - Page 2 at DVinfo.net
Old January 25th, 2010, 07:34 AM   #16
I have the same feeling, just looking at a red LED through it I can see how much it is attenuating the visible red part of the spectrum. By very crude measurements using the camera I'd say the loss is over 1 stop. By comparison the 486 shows no loss. The 486 stays on the camera.
Only reason I bought the T1 was to try it out and also to see if I could fit it behind my WA adapter.
Yes it IS attenuating the visible light spectrum, and yes - it DOES inflict considerable light loss.
Nevertheless, I find the T1 attenuation correctable much easier than the 486's green vignette, and as to the low-light capabilities - well... It usually so happens with me that the more I care for an event's colors being rendered truthfully, the better it's lit (more powerful stage lights, etc.).
All in all, my case is the opposite to Bob's: I used to have the 486 which I sold away, and now have the 77mm screw-in T1 AND its 4x5.65" version coming soon...
But keep it on at all times? Not at all!
Old January 25th, 2010, 09:32 AM   #17
I haven't had a chance to try mine out yet, but what problems do you suppose I will run into under stage lighting. What did you set the white balance to?
John
John Peterson is offline   Reply With Quote
Old January 25th, 2010, 04:58 PM   #18
Originally Posted by Simon Wyndham View Post
I could be wrong, but I felt that on the last shoot I did that the T1 made peoples faces a bit pasty. Again, it could have just been the light and I need to use it a bit more to be sure.
My understanding is that skin is a fairly complex thing. Not only is the outer layer reflecting light but the blood itself is reflecting deep red and IR which can penetrate through the skin.
What the T1 filter is doing is altering the response of the red channel sensor. White balancing does not correct this. Technically speaking the 486 filter gives more accurate color reproduction than the T1. Plots of filters similar to the T1 show this, interesting that Tiffen do not provide plots of the T1 whereas B&W do for the 486 and a warning about using it at wide angles.
I had hoped to get the T1 tested using the right equipment and I have gotten as far as finding a lab with the gear to do this. Unfortunately it's going to cost at least $400 and for me at least only confirm what I already know.
Old January 25th, 2010, 06:34 PM   #19
Tiffen have shown a general spectral curve for the T1 vs a stock EX. It does cut pretty strongly across the board.
http://www.tiffen.com/userimages/T1_IR_Charts_SS.pdf
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old January 26th, 2010, 05:28 AM   #20
Thank you so much for that David, that saved me either some money or a bit of jerry rigging.
For comparison the response curve for the 486 is on page 5 of this document:
http://www.schneideroptics.com/pdfs/...%20Catalog.pdf
Old January 26th, 2010, 05:44 AM   #21
Yes - spot on again, Bob. Having also noticed what you describe, I simply developed a special PP for those situations where I MUST use my T1, whereby a (quite wide) skin color range is shifted a bit towards red.
This (plus a proper white balancing) makes my pictures quite neutral, while preserving the blacks (and dark greens, and dark blues)...
Old January 26th, 2010, 03:23 PM   #22
I bought a T1 with little hesitation after a painful experience naively trying to match with a Z1. couldn't seem to get those browns to agree...
Any advice on good PP settings to compensate for T1 green tint would be much appreciated.
David Esp is offline   Reply With Quote
Old January 26th, 2010, 09:14 PM   #23
T1 ...
In conference or PR business shoots where the suits of the speakers seem to predominate in black ... I have noticed a difference between T1 and no T1. I've yet to have a skin tone problem but will check on that more closely.
Dean Harrington is offline   Reply With Quote
Old January 27th, 2010, 04:11 AM   #24
This shot was done using a Lowell DV Creator Kit #55, which is of course, all incandescent. You'll notice that the area of the black drapes lit by the hair light creates more IR contamination than other areas. Thankfully, all it takes to fix this is one click in FCP's 3 way colour corrector.
I have had 2 Tiffen T1 IR filters on order for a while now.
- Don
Last edited by Don Greening; January 27th, 2010 at 04:14 AM. Reason: adding attachment
Don Greening is offline   Reply With Quote
Old January 27th, 2010, 07:31 AM   #25
Don that Redish glow on the back curtain doesnt really bother the picture much, if i was analising this i would think that turning her into a red-head :-) would be the thing THEY would notice . In THIS case couldnt you just offset the light(s), solve the excess in the center, and kill the light reflection on the glasses in the same move?
that wouldnt cause me to stuff a filter on, thier skin tones look ok and all thier blacks other than her hair is ok. and the whole thing doesnt fall into the OMG look what happened realm. I can see it, but its not destroying everything at all.
If you can get them to smile, instead of worring about such excess technical stuff :-) why it wouldnt exist at all
----------------sig-----------------
Re-learning everything all over again, one more time.
Marty Welk is offline   Reply With Quote
Old January 27th, 2010, 02:01 PM   #26
We interviewed about 40 sets of people over a 2 day period in 2 different rooms. I was the card wrangler and hired 2 crews, including boom operators, to do the actual shooting with my gear. The lack of smiling was because of the subject matter: serious human rights violations. The frame grab was taken before that particular interview got underway.
- Don
Old January 28th, 2010, 04:20 AM   #27
My T1 arrived this morning after what feels like years of trying to get hold of one. Just done a few experiments.
Wow, it does fix the black problem. However the blacks still don't look quite as they look to the eye (or indeed my Z1). Highlights on them tend to lean towards being greenish. This is despite white balancing. The Z1 was coping just dandy.
Yes, there's also the loss of light. Not much but might be enough to be critical in marginal situations
Conclusion - It won't be staying on all the time as some people recommend. Instead I'll pop it on for interviews and specific material where I can see there is a problem. Otherwise you'll end up having to colour correct every shot to make it look more like the EX1 we know and love.
It's like any other filter I carry in the camera bag. I wouldn't leave the polarizer on all the time and I'm not going to leave the T1 on all the time either.
Would be interested to hear if anyone has a preset look for the T1.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old January 28th, 2010, 05:53 AM   #28
Markus,
There is no such thing as the "best" PP for the T1. The only thing I'm trying (with varying success) to incorporate into my own PPs (for those situations where I need to put the filter on) is some color correction (shifting the hue of skin tones towards red just a bit).
Old January 30th, 2010, 04:46 AM   #29
Thanks everyone for all your comments and suggestions.
I'm going to stay away from the T1 as much as possible
Today I was filming this girl in a black t-shirt. I noticed the black browning up in the flip out screen and put the 486 filter on. This fixed the shot and it looks really good even though there's not much light
The full wide wide shots did not show any vignetting that I can see
But on this grab of a shot 1/2 zoomed in you can see a weird blue corner
There's a window just to her right so I guess the rays are coming in at a low side angle and hitting the filter
I remember now I didn't have the lens hood on so that may have caused it
Apart from that a great day!
Steve Browne is offline   Reply With Quote
Old January 31st, 2010, 07:22 PM   #30
Yep, sure looks like a light flare to me, too.
Dave Morrison is offline   Reply
