EX1 Shoulder Mount System - Page 2 at DVinfo.net
Old February 3rd, 2010, 03:22 AM   #16
Yes Barry - the bottom line is that for the first time, I can use my EX1 as a proper hand-held camera, and get smooth and steady picture!
My RedRock "monster" rig will still have its use, but only where I have the tripod around - so that I can rest the rig on it in between those very short takes I can take with it before collapsing ;)
Old April 7th, 2010, 07:21 AM   #17
Originally Posted by Olof Ekbergh View Post
Piotr,
Good question. The way it works for using the on-cam viewfinder, is you swivel the back bracket to the right, so your head is in the right position to comfortable use the VF, and you also slide the camera forward all the way on your shoulder.
For using the LCD, you swing the back bracket to the left and keep the camera slid forward, so you have a good distance to the VF, I use a VF shade when shooting like that, it works well even outside in the sun.
For using the HoodLoop, you keep the back bracket straight back, and move the camera back on your shoulder so you are only using the small front bracket on your shoulder, this works very well, balance is perfect.
You can also remove the back bracket and just use the "lean" system if you have a Swit battery with a D-tap in the Camera. I like this a lot, it is a balanced and small system.
Does anyone know if you can use your left eye on the viewfinder comfortably? I'm "left-eye" dominant for focusing and I'm not sure it will work out for me.
Stefan Weiersmueller is offline   Reply With Quote
Old April 7th, 2010, 08:17 AM   #18
yes you can
Brian Rigler is offline   Reply With Quote
Old April 7th, 2010, 08:51 AM   #19
Just got back from a spring break cruise with the kids and shot over 3 1/2 hours of video - used the Shape WLB Spider II system once but the rest of the time used Olof's small shoulder brace (not the one hanging off the back) along with the smaller SWIT battery and it worked out beautifully. The system is so compact I can put it in a backpack easily and carry around.
Barry J. Weckesser is offline   Reply With Quote
Old April 7th, 2010, 08:00 PM   #20
Sponsor: Westside AV
I have made a custom fit for one customer where the large shoulder brace pivots to the left, and it is working for him. I think he just flipped the eyecup.
Contact me if you want more information on this mod.
olof@westsideav.com
603.383.9283
Westside A V Studios WEB Store
I also Skype, just email me to set it up.
