mini-d monitor output at DVinfo.net
Old December 22nd, 2009, 09:17 AM   #1
I'll be needing to feed 2 monitors. My near-camera monitor has SDI input and SDI loopthru.
But the second monitor only has RGB input. I'm thinking of using the mini-D output for the second monitor. How long a run can I have with an RCA RGB cable? Hoping to avoid buying converters for this; or a new monitor.
Ed Kukla is offline   Reply With Quote
Old December 22nd, 2009, 09:27 AM   #2
Sponsor: Westside AV
I would use a really good 75Ω BNC cable with bnc-rca adapters. With that you could easily go up to 50' or more.
I do that all the time. With Canare V61s cable. I make the cable myself, if you need a quote on custom cable, contact me. I can supply all the adapters as well.
B&H carries cable as well.
olof@westsideav.com
603.383.9283
