#46 |
Ian
Take a look at by Paul Kellett, a DVInfo member. To access the maintenance menu, press Menu while holding down Sel/Set and Cancel. |
#47 |
Well in that case that just Sucks :-)
----------------sig----------------- Re-learning everything all over again, one more time. |
#48 |
Sponsor: Westside AV
Does anyone know how to get the EX1R to display the maintenance menu?
#49 | |
My EX1 files via ClipBrowser show ND1 even when ND is not used, is this normal? Will this affect Auto FB? |
#50 | |
Thanks for sending the link of Paul Kellett's video demo of how to do a back flange adjustment with the EX1. I didn't even think it was possible to get into a maintenance menu system to perform this adjustment yourself. Very cool indeed. Should my cameras need to be "touched up" I'd rather do this procedure myself then pay Sony big $$$ to do likely the same thing to fix a focus problem. Thanks once again for posting your video! Ian Last edited by Ian Campbell; January 4th, 2010 at 01:04 PM. Reason: correction |
#51 | |
I don't know how the EX1's back flange adjustment really works. But when Sony, for instance, does work to correct a focus problem with a camera having a a removable lens they usually need to "touch up" / set up the focus for each of the ND settings. This is because a good camera has true (non electronic) glass filters. Each filter (the EX1 has two) has a different thickness. Also, each ND filter may have (like each glass element in a lens) slight imperfections that back focus adjustments attempt to correct as best as it can. This is why often doing focus adjustments for each of the ND's is useful. But whether you need to do a back focus set-up for each of the ND settings with the way the EX1 records back flange adjustment data is a very good question. I don't know if the camera has the capability to store and retain back focus data for each filter setting. Ian |
#52 |
Hi Ian, thanks for your answer. Tomorrow I will run some tests regarding Auto FB and different ND filters and report here.
#53 | |
Alister?
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#54 | |
Thanks.
#55 |
Hi Piotr, hi everybody and sorry for returning to this thread later than expected.
I run my backfocus adjustment with no ND filters at about 6 feet with a Siemens Star, and it didn't work, it was way off. Running the adjustment at 12 feet did it for me. I tested my camera's backfocus with targets at 6, 12 and 18 feet away and with each ND position (OFF, 1 and 2). Everything seems to be OK. Remember I haven't run any backfocus adjustment with ND filters. Of course, this is my case, it might not be yours. Maybe this thread bump caughts Alister's attention and he can clear this up. I'm still afraid though, so I have sticked the Siemens Star to the back of my clapperboard. Under controlled situations I will always use it in conjunction with the peaking function, with this method I guess it's impossible to fail under simple circunstances. On the other hand, this won't easily save me if I have some zoom-in/out shots, but at least it will let me know if everything is working properly or not. I wonder how the backfocus problem affects the shot transition function's focus, any insight? Cheers and good luck! May the Focus be with you. Ivan. |
