What does Update Media do? at DVinfo.net
Old December 6th, 2009, 01:23 AM   #1
the owner's manual has no info on this subject. on my EX1 in the OTHERS menu, under the Clip menu lies an option to Update: Media A, Media B. what does this do?
thanks.
Michael B. McGee is offline   Reply With Quote
Old December 6th, 2009, 02:47 AM   #2
I don't know specifically what it is designed for (maybe my use of it is), but if you do a transfer of a file back to the SxS card using XDCAM Transfer etc the clip won't appear to the camera on the card until you have run the update media option. Interestingly I have noticed that when I have exported files back to the SxS card they have appeared in the root of the card. So I suspect that Update Media creates a new folder inside the BPAV directory for the new clip.
Simon Wyndham is offline   Reply With Quote
Old December 6th, 2009, 11:59 PM   #3
huh, that sounds like a good answer.
Old December 7th, 2009, 12:52 AM   #4
When you delete a clip folder under the BPAV folder on a computer without using the clip browser software, metadata for that clip is still present in the MEDIAPRO.XML file.
The camera detects that the clip is missing and updates the MEDIAPRO.XML file to remove references to it. It may also work the other way round when a clip folder is added.
Omar Idris is offline   Reply With Quote
Old December 7th, 2009, 01:11 AM   #5
When you Update Media it adds the Title Prefix and the Number Set to the SxS card effectively changing the default clip title. I don't know if it has any other purpose but that's how I use it.
Aaron Fowler
PMW-EX1 / EOS 60D / EOS 550D / FCS2 / CS4 PP
Aaron Fowler is offline   Reply With Quote
Old December 15th, 2009, 06:35 PM   #6
really? wouldn't it just update on its own once you hit record?
