Cannot Proceed Message at DVinfo.net
Old November 18th, 2009, 11:33 AM   #1
I have the EX1 and have noticed when I am shooting and try to make changes to the White Balance or the gain control, I get a message in the viewfinder, "Cannot Proceed" Any idea why I get the message and how to bypass it to make adjustments?
Thanks in advance for your help.
Phil
Phil Hanna is offline   Reply With Quote
Old November 18th, 2009, 12:16 PM   #2
Are you using fully auto? Which WB setting are you using of the three?
Paul Inglis is offline   Reply With Quote
Old November 18th, 2009, 01:18 PM   #3
Here's The Fix:
Go to Menu and in the menu set that has the icon that looks like four squares (what does that icon even stand for?) look for "Direct Menu" and set it to "Part"or "Off". If it is set to "All" it will deactivate the gain and white balance buttons. Why? Who knows? But this is so random a lot of people when they first get the camera (myself included) freak out at this.
This thread should be a sticky because it confuses A LOT of new EX-1 owners.
Brian Mills, Videographer/Editor
www.gordovideo.com
Brian Mills is offline   Reply With Quote
Old November 18th, 2009, 02:07 PM   #4
Buy Mr Jensen's Vortex guide to the ex3 - all this stuff gets a mention. Can't imagine trying to suss that one out on the hoof.
David Herman is offline   Reply With Quote
Old November 18th, 2009, 04:06 PM   #5
If you had used the search box at the top of the page and looked for Cannot Proceed you would of had pages of results. This needs to be a sticky as it comes up almost weekly.
Old November 18th, 2009, 08:18 PM   #6
Thank you all
I appreciate the fast response and I should have checked the knowledge area first. I do have Doug Jensen's video. Excellent material.
Phil
