Thread Tools
Search this Thread
Hard Reset button on ex1? froze at xdcam screen
Anyone know if there is a hard reset button on the ex1? The camera is frozen at the xdcam start up screen and just turns itself on and off. I can't access the menu so the in-camera reset is not an option. Anyone else ever heard of this problem?
Yikes. A quick search of the owner's manual pdf didn't see any hardware reset.
Have you tried removing the battery and all the cards? Let it sit like that for five or ten minutes and try again. Sorry to hear that your cam has lost its mind.
EX3, Z1U, FX1, D1X / NeXTstation Turbo Color / FCS3 |
Help I just experienced tyhe same problem on a shoot. Tony did you find out what this was?
Perhaps removing the backup/settings battery would help?
#5 |
where is that battery?
#6 |
From page 125 of the manual:
1. Open the cover of the backup battery holder on the bottom by loosening the screw, and remove the battery. (Illustration: directly next to the tripod mounting plate) 2. Insert a new backup battery (CR2032) with the + symbol facing outside. 3. Attach the cover in the original position. |
#7 |
EX-1 won't boot - Help!
My Ex-1 will not boot.
The camera gets to the xdcam start up screen and then just turns itself off then on again over & over. I can't access the menu so the in-camera reset is not an option. I have tried A/C & batts. Tried starting with the switch set to media. Tried changing the cr2032 battery ( I think I installed it correctly - it didn't seem to fit very well. Help? Lenny Levy |
#8 |
Try removing (rather than changing the internal battery) and leave it out for many minutes (even a day to sure but just a few minutes really might be enough). Turn the camera on/off during that time to ensure any residual charge is drained as well. Then reinstall the battery.
#9 |
Craig,
Thanks for responding. Do you know that will work or is it just a guess? Otherwise I am about to send it off for repair ASAP. I'll wait if its a pretty sure bet. I already did leave the battery out for a good 1- 2 hours yesterday when I bought a new 2032. I found it tricky to get the replacement to lay in correctly though I eventually got it. Lenny |
#10 |
It depends on whether the issue is software, firmware, hardware related. Not only is that not sure neither is Sony's repair. It all depends on whether you can try one more thing vs a possible 3 week turnaround by Sony.
#11 |
I guess you removed all the SxS cards and tried it?
I would also try holding down the menu button, menu scroller, and cancel button when staring up. That's what I'd try... |
#12 |
Camera is at Sony guys. They don't know what's wrong with it yet. I'll let you know when I get it back. Apparently I'm not the only one with this problem...
#13 |
Tried all of that stuff to no avail. Any ideas folks. For others who did the firmware upgrade yourself: does your battery still die if left on the camera.
Lenny Levy Last edited by Pete Bauer; October 19th, 2009 at 12:38 PM. Reason: Removed text about a phone call to Tony Edgar - original text in Reported Post thread |
#15 |
The firmware upgrade didn't do anything about the battery discharge problem. That requires a circuit board replacement.
Pete |
