Thread Tools
Search this Thread
A fix for EX3 viewfinder fogging?
As the weather starts to cool here - how is the best way to avoid having the viewfinder fog?
I had a problem with that earlier in the year... |
Just use anti fog wipes. Clarity Fog Eliminator Towelette Wipes
When that's happened to me, it's been due to dragging a camera through a rapid change in temperature such as coming indoors after shooting outdoors in the cold for a while. A trick I learned years ago, and learned the hard way, was to put the camera in a ziplock bag before I bring the camera indoors (well, my handicams and SLRs fit in a extra large ziplock bag - do they make ones large enough for the EX3? Maybe kitchen trash liners would work). The important thing is that the air in the bag needs to be from the outside before you close it. Then you bring it inside wait for the camera to get up to the temp of the room and then take it out of the bag. Unfortunately, that's measured in hours.
I suppose if it's just happening to the optics of the viewfinder, you could just remove the viewfinder and put it in a ziplock bag. I'd want to do the whole camera, though, so no condensation gets on the lens elements. If the viewfinder element is fogging when you're outside, that's another matter and probably has something to do with your body heat or something like that. Condensation happens when warmer, moist air hits something colder.
EX3, Z1U, FX1, D1X / NeXTstation Turbo Color / FCS3 |
It can be a problem when you are operating.
Allow a little air space between your skin and the finder seal. Don't make a tight seal. Allows circulation. Try one of these Eyepiece Chamois Cushions by Bluestar - Chamois Leather, Fleece, Microfibre Try anti-fog juice (at your own risk). I've used it on HDcam camcorders and it's helped. Or go for the tried and true staple of TV camera operators worldwide. The celebrated wrist band. I prefer underarmour. Fit it over the rubber cup and youre good to go. More comfy too! Use the juice, wristband and air space together and fogging should be virtually eliminated. |
#5 | |
If this one works better, then great. (don't have much need for it however around my neck of the woods ;-)
#6 |
I have been doing a lot of filming in the rain. The problem is the eyepiece fogging from the heat from the eye.
I use a fluid called Rain-X or Rain Clear from Turtle Wax. I have used this fluid on the outside front port of my underwater housing for years. Whipe on twice with a soft tissue, let dry, and polish and rinse with a clean soft tissue and clean water. I would never use this on my front camera lens or anything that is not replacable. You can destroy the surface! I have used it on a UVfilter in front of my lens with success. I always carry a big wacuum bag in my equipment case. This is a big Ziplock bag used for vacuum-packing cloths with a vacuum-cleaner. Its soft durable and transparent plastic. I make a whole for a filter for my camera, and straps it with nylon strips or tape. I have used this bag, filter and Rain-X, and filmed a whole day in and out of the warm springs on Island with success. Like a cheap Ewa-bag. But not for underwater use;-) -arnt |
