#76 | |
The only thing I needed to do was to move the whole rig just an inch backward relative to the shoulder pad, and replace the big Hoodman eyepiece with the smaller, circular one. My impressions on using the Hoodman EX1 kit with naked EX1 are equally positive (see http://www.dvinfo.net/forum/1397023-post32.html) Congrats Hoodman; thanks Lou!
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#77 |
I'm thinking to roll my own shoulder support. After a lot of running (walking actually) and gunning my right arm was very weary. I don't think the solution needs to be complicated. One of the earliest devices posted here was a simple metal strap the went over the shoulder. Front has a release plate for the camera, back has a cage for a battery or any form of weight. I think such a thing needs to be custom made to fit or else be bendable to fit.
All that needs to be achieved is to get some of the weight off the right arm and reduce the torsion on the wrist. I think the later is more the problem than the weight. |
#78 |
Yeah Bob, I'm heading that way too. Every shoulder mount I look at seems to have something I do not like. Then there's the price. I'm still in the design stage but thinking of incorporating detachable rails into my baseplate design.
Here's my baseplate I knocked out one morning. The hardest part was finding the aluminum, but I found a piece in my shop. Total out of pocket might have been $1.50 for two longer metric screws that I did not have in my bins. |
#79 | |
So I cut the pad away from it's arm and bolted a telescoping golf ball retriever in it's place. Now I have an adjustable length arm that drops over my belt. Makes long, standing shots easier than with my D600 BetaCam rig. It's even a surprisingly good stabilizer for walking shots. |
#80 |
Can you post a piccie of your adapter? I thought about adding a very soft latex pad that would "soak" up your breathing rythm. |
#81 |
Ok, so, i see the link to the Opteka support....and freak out.....I ordered one right away. For $30 how can you go wrong? If I don't like it, it's not like I'm out a bunch of money. It never hurts to have options. I already have a wrist shot that works wonderfully, however, the arm still gets very tired. For wakeboarding, the wrist shot is awesome. For other scenarios this Opteka is awesome! On top of that I'll probably still get a really nice shoulder mount as well. Those generally leave my arms tired but seem to work better than the opteka or wrist shot for walking and shooting. Different tools for different scenarios. It never hurts to be prepared.
#82 | |
I found this sytem quite comfortable using it for two hours today - no shoulder strain and no weight supported by either hand - totally free to make the usual manual adjustments. |
#83 |
I still have some pics of my old design on-line if anyone is interested.
here's the gallery link; My_Ex3_Mount cheers, Evan |
#84 |
That's a cool design, Evan - however, I don't know if strapping a brick of C4 as a counterweight is a good idea... :)
#85 | |
I noticed in your pictures you were using the QRPro to raise the camera up to eye level. Would you think that Shape-WLB's Shape Box option would give you the same approximate room, albeit with half of the "accessory" space that you have with the QRPro? Also on this subject, is the Spider's ability to raise/lower the camera with the shoulder adjustment not sufficient to get the camera up to your eye, such that if you didn't have the QRPro, you could still get the camera up to eye level? Also, in your pictures you have a waist strap that the support arm cup is sitting in for stability. What are you using for the waist strap? I find it odd that Shape-WLB doesn't offer any solution or guidance for this beyond what they have... |
#86 |
Barry - one more question (sorry). It's not called out explicitly on the Shape-WLB website, but I wanted to confirm that unlike the DVTec MultiRig and associated stabilizer products, the Shape-WLB doesn't have a spring-loaded stabilizer arm - that the arm is rigid, and doesn't have any "play" in it? Does this, in your opinion, not cause your body's movement at the hip, for example (where you have yours resting), causing movement at the camera's level?
#87 | ||
Actually choosing the Spider II consisted of two factors - (1) the QRPro2 is a permanent (as far as I am concerned) addition to the camera - it serves as a Nanoflash and battery mounting platform and also an aide in handholding the camera not allowing the camera to flip to one side when you hold it with your right hand (the plate rests against your arm) -(2) I find that I have gotten used to the Hoodman HoodLoupe and do not want to be without it. The Spider II is the only mount that allows you to keep the camera significantly BELOW shoulder level so that when the QRPro2 is mounted it is still 1 1/2" below my shoulder peak. This is "eye level" for me as it allows me to tilt the HoodLoupe LCD combo DOWN so that my face doesn't rest against the fat part of the camera body. If you didn't have the QRPRO2 and had the camera adjusted at the top level - the bottom of the camera would be 2 1/2" below your shoulder tip - just try your camera out at this approximate level and see how comfortable that is. Yes, you could use the SHAPE box to raise the camera up but if you aren't going to be using the HoodLoupe or adding an accessory holder below the camera then look around the SHAPE WLB website and this might be more suitable for your needs: Shape WLB - RED MAMMOUTH II camera support - RM4200 - with this unit the camera is positioned 3/4" above your shoulder peak and can be moved back and forth in a 6" slot. With regard to the waist strap - it is quite good - Velcro - easy on and off and has two pockets that exactly fit the rubber plate at the end of the telescoping arm - it is from SHAPE-WLB - very new - just hasn't been put on their website but you can order it over the phone - it is definitely a good addition to this system. With regard to your question about the arm - from the SHAPE website: "The TELESCOPIC SUPPORT ARM is a Manfrotto 233B Camera Mount Bracket (without the Manfrotto 143BKT camera plate). The arm can be extended from 14" (36 cm) to 20" (51 cm)." It IS spring loaded and has an adjusting bracket to stop it from moving but I think, even with the spring, it will still transmit some body movement. |
#88 |
#89 | |
#90 | |
Brett Sherman |
