Sony EX1 Media Restore! - Page 2 at DVinfo.net
Old July 12th, 2009, 10:10 AM   #16
Originally Posted by Mark Savage View Post
I get the "Restore Media" message after I have offloaded the cards to a drive. Usually I will restore before Deleting All clips off the card.
That may happen depending on how you copy the files. I use ClipBrowser (always CRC ON) and that never happens. It is possible when using Finder (drag and drop or deleting clips) the OS writes and invisible file to the card (another reason never to drag and drop IMHO). The camera sees the "alien" file and sees it as a metadata issue and thus, "Restore Media."
I only delete clips in ClipBrowser or from the camera menu.
Old July 12th, 2009, 02:09 PM   #17
I thought I would share this with you all.
Here are the results of the overcrank test I have just performed on the cards.
First Card - Transcend.
20 sec at 40fps 720/25p
20 sec at 38fps
22 sec at 36fps
24 sec at 34fps
22 sec at 32fps
29 sec at 30fps
over a minute at 28fps.
Second Card - Transcend.
24 sec at 40 fps
21 sec at 36 fps
over a minute at 32 ending with media error on pause!
Third Card - Transcend.
24 sec at 40 fps
27 sec at 36 fps
26 sec at 32 fps
Forth Card - Sandisk.
Over 2 min at 40fps - no error
over a minute at 44 fps - no error
over a minute at 48 fps - no error
1.08 at 50 fps - Media error.
Cheers.
John De Rienzo is offline   Reply With Quote
Old July 12th, 2009, 03:21 PM   #18
If they all were new cards, that sounds like a bad batch problem to me. If they are cards you have used successfully in the past..... I just don't know!
After seeing those figures, looks even more like a bad batch problem. Can you confirm they were all brand new cards, that you hadn't been using them successfully in the past?
Old July 12th, 2009, 04:12 PM   #19
Well, those test results are indeed revealing and explain why you are having problems. If the SDHC card cannot support 48fps at 1080/24p or 25p then it simply does not have the headroom to manage the data burst as the camera writes its cache to the memory card. This has been thoroughly debated on that very lengthy thread concerning SDHC memory cards.
It is also worth noting that SxS cards also need some time, when the red light is on after stopping the record process -- while the camera writes out its cache to storage. This latter characteristic is just the way the EX camera works regardless of how fast your storage card/medium is.
Barry J. Anwender is offline   Reply
