XDCAM How to clips by me! - Page 3 at DVinfo.net
Old June 3rd, 2009, 05:37 PM   #31
With an EX only by building a controller and then using frame record, but it would be tricky to set up. For those kinds of sequences a simple digital stills camera is the way to go, stiching the stills together with you edit software. I've done sequences over weeks and months that way. There are plenty of cheap controllers on ebay for timelapse with DSLR's.
I've had a controller made by these folks for several years. I used this one:
Digisnap 2100 | Harbortronics
to make this short timelapse on Vimeo:
Twilight timelapse on Vimeo
Their other models can control all sorts of camera functions including flash.
dave
Old July 14th, 2009, 04:26 AM   #32
XDCAM EX Marix - what it does
I have posted another XDCAM EX how-to video on you tube. This one is on the Matrix.
YouTube - XDCAM EX Color Matrix Setup and How To instructional video
Old July 14th, 2009, 05:01 AM   #33
Thanks Alister,
It was nice to see examples of the different matrix settings.
Well explained.
Kevin Jones
Kevin Wayne Jones is offline   Reply With Quote
Old July 14th, 2009, 05:30 AM   #34
Great tutorials clips Alister , since i see you everywhere on internet can i ask about your workflow from HD to SD.
I got a very informative discussion about it with Doug Jensen of Vortex Media here.
http://www.dvinfo.net/conf/sony-xdca...ug-jensen.html
By the way your demo on Sony website for NAB 2009 was very great to look at.
I think doing it for HD and SD at the same time is probably like what i need the most.
Production D. Goyette - Production Video Corporatif - Montreal Quebec Canada.
https://www.facebook.com/ProductionDanielGoyette/ , Vimeo , Youtube, Facebook.
Daniel Goyette is offline   Reply With Quote
Old July 14th, 2009, 08:32 AM   #35
If the main use of the material is SD then I shoot 720P50 edit at 720P then output as SD PAL, you would use 720P60 and NTSC. If the primary use is HD or uncertain then I shoot 1080P25 with detail level set to -10. I edit HD then downconvert using compressor.
Old July 14th, 2009, 11:42 AM   #36
Alister;
That's the best explanation of matrix settings I have ever seen. Thanks for that.
Pete
Clark Peters is offline   Reply With Quote
Old July 15th, 2009, 12:17 AM   #37
Glad you like it. Cinegammas will be the next one.
Old July 15th, 2009, 03:01 AM   #38
Howdy,
I like your calm and measured style. It is unconvoluted and to the point instead of going in 10 different directions explaining one thing.
Was it by eye only that you determined preferences of level +30 and the different matrix looks or was it in conjunction with a vectorscope.
Max Allen is offline   Reply
