How can I record Audio 1 to both channels ? at DVinfo.net
Old April 20th, 2009, 05:17 AM   #1
Hi :)
I was pretty sure, that I managed to do that. Or was it only with the Z1 before ...
Anyway:
I want a microphone in Audio1 and then record that to Channel 1 and 2 simulaneously.
What's the correct menu setting for that ?
Peter
Peter Rixner is offline   Reply With Quote
Old April 20th, 2009, 06:17 AM   #2
Menu > Audio input > Ext Ch Select CH-1 (records to both channels from input 1), what you want.
CH1/CH2 records them seperately, not what you want.
Page 102 of the manual, for EX1 anyway.
Paul.
Round 2
GH5,FZ2000
Old April 20th, 2009, 09:06 AM   #3
But that's exactly what I did. And it only records on Audio 1.
Strange ...
Peter
Old April 20th, 2009, 09:49 AM   #4
Make sure that Channel 2 is set to the same input as Channel 1. I had this problem before and realised that Channel 2 was set to Line and not Mic...
Ollie Wright is offline   Reply With Quote
Old April 21st, 2009, 06:49 AM   #5
Hi Ollie,
Thanks! That's it :)
Peter
Old April 21st, 2009, 07:58 AM   #6
Can you then adjust the levels independently? I like to have the same source recorded one channel hot and the other lower in case there is clipping. If so this is a great feature.
Previously I'd used a XLR splitter.
Keith Moreau is offline   Reply With Quote
Old April 21st, 2009, 09:07 AM   #7
Sure you can, even other audio settings ( limiters) are operational.
Br. Atti
Atti
Attila Cser is offline   Reply With Quote
Old April 21st, 2009, 04:20 PM   #8
The only reason that I'd consider recording the same audio to two different sources was if I could lower the gain on one of them about 5db so that I avoid clipping... why not just record to one audio source and simply set it to mono in post?
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old April 21st, 2009, 05:25 PM   #9
Just set both volume controls to manual and set one slightly higher than the other, i'm talking about the trim wheels on the back of the camera.
Paul;.
Round 2
GH5,FZ2000
Paul Kellett is offline   Reply
