White Balance For Night Shoot? at DVinfo.net
Old April 15th, 2009, 03:54 PM   #1
I will be shooting at night without being able to do a white balance,
could someone suggest a color temp setting?
Thanks.
Kevin Jones
Kevin Wayne Jones is offline   Reply With Quote
Old April 15th, 2009, 04:22 PM   #2
Use your "pre-set" white balance...it has worked for me in the past.
Bill Griffin
SONY PXW-X320,PMW-300K2, LiveU LU-500,Sound Devices 552 Mixer,www.Dallascamguy.com
William Griffin is offline   Reply With Quote
Old April 15th, 2009, 04:38 PM   #3
Do you mean ATW?
kj
Old April 15th, 2009, 09:09 PM   #4
I'd like to know what people are using as well. I'd start with 5600, but I noticed that at dusk, 5600 doesn't work too well (can't remember which direction I went to make it look good. Maybe start with 5600 and see how that looks.
Sorry I need to spend more "non-work time" with the camera. I'm looking forward to going on some fun nature shoots when things get green around here.
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply With Quote
Old April 15th, 2009, 09:33 PM   #5
Just before you shoot white balance to something white and this will tell you the temp, this only takes less than five seconds.
If your shooting with lights around you do the same.
Easy
Old April 16th, 2009, 02:30 AM   #6
That depends on where the ligt comes form. In nature I would select 5600k as standard or take a white balance just before the light disapers. It will do for most shots - like the moon. You can always check the colour viewfinder to check if 3200k is better if you make something with cars and a city.
Bo Skelmose is offline   Reply With Quote
Old April 16th, 2009, 03:18 AM   #7
At night the 3200K usually reset works best. At sunset/dusk you have to make a judgement call when the sun is the main source 5600K preset works extremely well. You can either keep this setting, or once sources like headlights become dominate you switch to 3200K. It's usually so blue from the reflected light from the sky by this time that it's not a huge difference once you make the switch.
For street lighting it depends on type of lights being used and if there are other lights on shot. With sodium the 3200K preset usually looks OK, especially if you have other light sources. Some cameras will improve the look of sodium if you take a white balance, but these lights have a narrow wavelength and never really look that great.
Taking a white balance on the setting sun gives an unnatural look with extremely blue shadows.
If you've got a monitor you basically go for what looks good.
Old April 16th, 2009, 11:52 AM   #8
I agree completely with the 3200K setting. This has worked for me under most circumstances.
John
John Peterson is offline   Reply With Quote
Old April 17th, 2009, 08:21 AM   #9
And if all else fails, do a colour correct in FCP (or whatever editing system you use)
Shaun R Walker is offline   Reply With Quote
Old April 17th, 2009, 09:25 AM   #10
Kevin,
Why would you be able to do a white balance?
If the camera will be unattended then I would go the night before and look at the light sources around where the camera will be and white balance the camera. Then keep that setting for the next night.
Tim Polster is offline   Reply
