HD-SDI out from SxS cards? at DVinfo.net
Old April 10th, 2009, 02:12 PM   #1
When I play back material shot in the field I can't see the clip from the SDI output. Is that the case or do I just have a switch flipped wrong somewhere?
Marc Myers is offline   Reply With Quote
Old April 10th, 2009, 02:15 PM   #2
Images: 10
did u turn it on in the menu...the manual is your friend
Old April 10th, 2009, 02:37 PM   #3
Sponsor: Abel CineTech
Make sure your YPbPr/SDI Out is set to HD or SD in the Video Set menu. There is no menu setting that would disable playback.
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old April 14th, 2009, 12:15 AM   #4
Make sure the i.LINK is off, If the i.LINK input/output is enabled, no signal is fed out from
the SDI OUT.
Belinda Pan is offline   Reply With Quote
Old April 14th, 2009, 05:28 PM   #5
also make sure you're in 720p or 1080i mode depending on your monitor settings
Ed David is offline   Reply
