Advice needed for picture quality testing
Hi everyone,
I own an EX1 since a couple of weeks and I've been testing it for a few days. It is a great camera, offering a large range of possibilities for sure. But as a matter of fact I've never been able to produce clean images. There's always some kind of noise in the frame, sometimes even in well lightened situations on clear (in mean no shadows) surfaces. I'm in manual everything, AGC is off, no extra gain (I use to shoot -3 or 0db, maximum I use is 3db). Whatever picture profile I set, it's always looks like something's going wrong. I've been testing without PP, Bill raven's PP, Alistair Chapman's PP, and a lot of other ones, I've read topics about gammas and noise in the shadows on this site, but so far nothing helped me to get rid of this strange noisy picture. When i look at some footage I've made it just doesn't look right compare to others EX1 footage on the internet. Unfortunately, I have'nt a second EX1 to compare side by side the footage they produce. But before thinking it may be a deficient sensor unit I would like to test it properly so that's the point of this thread : Have you any ideas of tests I could do, then post for you to see, in order to make sure that the issue came from my use of the camcorder and not from the camcorder itself. |
Have you tried turning off the Detail yet?
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor |
how are you watching the footage to see the noise?
on PC? on HD TV? etc and what connection method are you using? |
Detail is usually turned off (or -8 when I use Alistair Chapman's PP).
Unfortunately I can only view my footage on my PC monitor Samsung Syncmaster T220 (22" wide) wich has a resolution of 1650x1280 at max, so for now I only shot in 720p for the screen resolution is not enough to watch 1920x1080 full screen without rescaling. I transfer my footage via Clip browser software 2.0. I create one instance of the file by drag and drop (so it turn to be a mp4 file) and i export an other one as an mxf (for editing purpose). I cannot see a difference between the two file types when played on VLC. |
#5 |
Is there anyone out here who can think to a simple kind of test to actually verify if the lens is OK or if it does have a sensor problem?
I will post result footage. I thought to shot a few seconds with iris fully open, no PP, and lens hood closed to see the amount of noise on a total black screen? |
#6 |
There is always some noise in the EX's pictures. HD cameras do tend to be noisier than SD cameras. Computer monitors are not the best way to view footage and can make noise look worse than it perhaps really is. I would try to find a way of looking at your pictures using a proper HD monitor. Have you looked at the SD output on a decent monitor, does this look just as noisy?
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#7 |
I've actually read on this forum -3db decreases the range on the camera... In fact, shooting with standard settings - not cine - at 0db gives you the fullest range much to my surprise.
I'd recommend purifier by innobits to remove most of your noise as it has saved my @#$ shooting high contrast beaches in hawaii... |
#8 |
Sorry Greg,
but what do you mean by "purifier by innobits"? |
#9 |
Google is your friend:
innobits.com - It is all about visions Why would you get noise shooting beaches in Hawaii? I would think there would be plenty of light in that situation. But then I've shot very little bright outdoor scenes with this camera (it's been pretty gloomy since January when we bought it) :)
#10 | |
All in all, I guess we have to live with that, and learn to use optimum settings for each individual scene / lighting conditions.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#11 |
I've used quite a few cameras in the EX price range, the EX1 fairs among the best in noise levels.
Also, of course we all know the settings and picture profiles can help to find the best image under a given situation. |
#12 |
Thanks Greg and Mitchell,
Google is my friend you're absolutely right! I guess we were not talking about Tolkien's mythology "in(h)obbits" but about an existing plugin to denoise footage... Ok I get it! Anyway, I've uploaded a piece of my EX footage to get some more feedback about this "issue". Clouds timelapse - EX1 Noise test on Vimeo Note that the online version is highly compresssed, so download the original file which is straight from the SxS card via clip browser software, no correction or edit. |
#13 | |
#14 |
Going by the specs you listed on the Vimeo site, I'd turn off SLS immediately. This will enable you to quit using f16 and you'll regain your image sharpness. I'm curious why you were using SLS in the first place? This additional exposure time might be causing some of the noise buildup, but I'm just guessing on that one.
#15 |
At an earlier point in the thread you say that you are shooting 720, may I suggest shooting at the cameras native 1920 setting, and avoid in camera scaling - for me I find 720 images horribly muddy and soft as compared to the full raster output of the EX1.
Viewing on a computer monitor is also no way to investigate problems with footage from this camera, at least look at the image on a broadcast specification monitor via HDSDI or at least, component analogue. You say that you are trying to avoid scaling on your Samsung, give the camera a chance and let it shoot what it designed for - 1920x1080. Oh, yes, never use anything higher that F8, your image will get more soggy the higher the F stop, try for the optimum F5.6. just my 2€ Paul
Another Sunny Day in Ibiza |
