12 Volt charging at DVinfo.net
Old February 26th, 2009, 02:57 PM   #1
12 Volt charging
I am about to take my EX1 on a trip where the only source will be the power outlet in a car (12V DC). I have done a quick scan and can't find any chargers that plug into the 12 V power out from a car that I can use to charge my EX1 batteries. Is anyone else using one of these and if so where did you get it.
Graeme
Graeme Fullick is offline   Reply With Quote
Old February 26th, 2009, 03:11 PM   #2
best bet is to get a 12V DC inverter to local voltage (220v) then use the sony charger as normal
Matt San is offline   Reply With Quote
Old February 26th, 2009, 03:12 PM   #3
I bought a 12V to 120V inverter, then use the standard battery charger.
Pete
Clark Peters is offline   Reply With Quote
Old February 28th, 2009, 12:23 AM   #4
For all kinds of AC powered equipment, I've found the most economical solution is to get a 12V to 120V or 240V converter (if that's your power). They are getting really small and inexpensive nowadays, with more and more watts power. The last one I got at Costco was about $20 for about 100w and quite small, like the size of 2 packs of cigarettes.
I recommend this to most people instead of getting and adapter device that uses 12V directly. Plus you don't wind up with a lot of extra 12V powered equipment that you rarely use.
Keith Moreau is offline   Reply
