SxS cards mount inconsistently at DVinfo.net
Old February 19th, 2009, 04:25 PM   #1
Does anyone have mechanical problems with their Expresscard slot? I'm on a Macbook Pro and I've got all the drivers and all that- I've worked with media from SxS cards plenty. But some of my cards don't always mount when I insert them. I think it's a mechanical problem, because when the card doesn't mount, all I have to do is apply pressure with my finger against the card, and then it mounts. If I let up on the pressure, it dismounts. Some of my cards don't seem to have the problem, and some do.
Anyone have any ideas? Do I have a faulty card slot that needs to be replaced? Thanks...
MBP 2.4 ghz core 2 duo, OS 10.4.11
Andy Schocken is offline   Reply With Quote
Old February 19th, 2009, 04:47 PM   #2
I thought that was a known issue on some MacBooks...
Old February 19th, 2009, 04:55 PM   #3
I've read that MBPs can sometimes have issues with the expresscard slot (it's a bit weak/not that well engineered for ruggedness, apparently) and so I'm dead careful with my mid 2008 version MBP (and so far so good). Also, look on the MBP forum on the (official and unofficial) Apple sites and read stuff on there about this.
Sounds like you need to be talking to Apple and getting it sorted ASAP. This is why you (I hope) have an Applecare warranty in place.
Old February 19th, 2009, 09:59 PM   #4
Yes-- same issue here. 2007-model 17" MBP. I find that with cards that don't cooperate that if I push them in good and snug that they will stay, but when the card is in, I don't disturb it at all!
I'm hoping that the MxR cards I have ordered do better with this-- it seems that some cards are more prone to the problem than others.
Nathan Lawrence is offline   Reply With Quote
Old February 20th, 2009, 03:45 AM   #5
I just take SD HC cards and place them in a card reader - no problems at all. Make sure the reader handles SD HC cards, a normal SD reader will not read the HC card versions.
Old February 23rd, 2009, 10:56 AM   #6
Thanks for the feedback. Yeah, the expresscard slot needs to be replaced. I'm covered by applecare, but the problem is I'm getting quoted 5-7 business days for diagnostic and repair. I can't be without my computer for that long.
Is there any kind of expresscard adapter that would be basically a female to male adapter (I know it wouldn't make sense to make one that's just for a single card female to male, but perhaps there's a dual female to single male)? As some cards work fine in the slot, it's possible that that could work for me.
