EX1 - Finding a replacement composite cable at DVinfo.net
Old February 16th, 2009, 11:23 AM   #1
Images: 10
I'm looking for a spare composite output cable (which I can butcher) for my EX1.
I need to run a monitor whilst on my jib, but I don't want to have the 3 phonos flapping around, so I looking for a spare cable or just the connector on it's own...
Is it available anywhere? Is the connector similar to another bit of Sony kit?
Cheers folks.
Old February 16th, 2009, 01:38 PM   #2
not sure where u can pick you up but i can tell u its a very cheap cable and is an exact copy of the one that came with a crappy hand held cam i picked up for cheap. any AV store, or sony supplier should be able to help, its a common sony connection
Daniel Alexander is offline   Reply With Quote
Old February 16th, 2009, 01:43 PM   #3
I chopped the original cable for the pilot, and now for the external monitor I'm using one that came with my HC9, they have the same connector.
Old February 16th, 2009, 02:16 PM   #4
Images: 10
All the Sony camcorders I own (5 different ones) have different outputs.
Thanks for your relies so far.
I'll search for an HC9 cable.
Cheers, Duncan.
Old February 16th, 2009, 03:59 PM   #5
The EX1 composite cable is available at the Sony Style store or BH Photo.
Gints Klimanis is offline   Reply With Quote
Old February 16th, 2009, 07:04 PM   #6
If this is true (I haven't actually looked to verify) let me know.... I have about a dozen HC9's that I use for wildlife research, and don't use any of the cables packaged with the cameras. I have all the boxes stacked up in a storage area with all the cables, software, etc. still in them. I'd be happy to send you one of the component cables-
www.zooprax.com
Derek Reich is offline   Reply With Quote
Old February 16th, 2009, 07:38 PM   #7
I've posted the link to the cable twice now. it's here, somewhere in the forum.
Sony EX1 v1.11, crap loads of SxS, Macs w/ Final Cut Studio
Andrew Hollister is offline   Reply With Quote
Old February 16th, 2009, 08:00 PM   #8
http://www.dvinfo.net/conf/sony-xdca...ut-ex-1-a.html
Any sufficiently advanced technology is indistinguishable
from magic. AC Clarke
Bob Jackson is offline   Reply With Quote
Old February 17th, 2009, 07:35 AM   #9
Images: 10
Thank you everyone!
Duncan Craig is offline   Reply
