EX3 DC Plug Specs at DVinfo.net
Old February 12th, 2009, 10:43 PM   #1
EX3 DC Plug Specs
I'm making a custom cable to power my EX3 through the DC input. Some googling leads me to believe I need an EIAJ04 plug and the centre pin is positive.
Can anyone confirm or deny this? Thanks!
David C. Williams is offline   Reply With Quote
Old February 12th, 2009, 11:56 PM   #2
Cannot confirm or deny... but this cable can be useful:
4-pin XLR to DC adapter cable for PMW-EX1/PMW-EX3
Thank you.
Ilya Spektor is offline   Reply With Quote
Old February 13th, 2009, 12:53 AM   #3
Thanks, I've seen that one too. Mine needs to be much shorter to a Switchcraft 761K. I have a funky setup on my Flyer-LE.
Old February 13th, 2009, 03:17 AM   #4
You are correct. I managed to buy a quantity of them from a local supplier so they're nothing too hard to track down. However the ones I have are not right angle entry. You may be able to buy RA ones but they'll most likely be already molded onto a cable.
There are some types of solder on connectors available in R.A. but such small sized R.A. plugs never seem overly successful to me.
Old February 13th, 2009, 03:33 AM   #5
Thanks, I think I've found just the thing from wagner.net.au, the MP204RA, right angle solder. $1.75AU each. farnell.com list the same thing as MP-204L.
