Filter for IR contamination - Page 13 at DVinfo.net
Old April 10th, 2009, 06:05 AM   #181
Originally Posted by Krikor Djevahirdjian View Post
Does anyone know the difference between the B+W 77mm 486 UV/IR Slim and the B+W 77mm 486 UV/IR? One is Slim and the other one is not.... but my question is does the not Slim model fit in the EX1 with the hood on?
Yes, it does.
Bill Heslip is offline   Reply With Quote
Old May 28th, 2009, 09:53 AM   #182
3 months later...
Originally Posted by Ryan Avery View Post
Let me set the record straight as it stands right now:
I must make it abundently clear that the True-Cut IR 750 is the best solution for the RED camera and any RED user should buy that filter for their camera if using heavy ND filters. The application of the True-Cut IR 750 is only less than ideal for Sony EX users (but does work in some shooting conditions!).
Your patience is appreciated and we are likely to have a workable solution soon.
Ryan Avery
Schneider Optics
Hey Ryan - how's that "workable solution" coming?
Ronn Kilby is offline   Reply With Quote
Old May 28th, 2009, 03:01 PM   #183
Art Adams and I, together with Robert Orlando from Tiffen just completed some tests of Tiffen's prototype dye based IR filter for Tungstun on the EX-1. Actually it might be more accurate to say its a filter for "far red" problems rather than just IR, but I'll avoid that complexity.
I am extremely happy to report that Tiffen has appeared to completely solve this problem.
The prototype is slightly green so requires a white balance, but it completely solves red in black materials under tungstun or daylight and regardless of how much ND you shoot with. One filter solves all.
This was only the prototype and I don't know how soon it will be in commercial production. The final version I expect may be even make us happier.
Thanks and kudos to the engineering team at Tiffen.
Lenny Levy
Old May 28th, 2009, 03:10 PM   #184
Good news, Lenny. One question that I've been meaning to ask: When reference is made to ND filters used in conjunction with this (or any) IR filter, are you strictly speaking about "external" ND filters stacked under the IR filter OR does this apply to the internal ND filters in the Sony? Sorry for the "duhhh" question, but this has always been fuzzy for me.
Old May 28th, 2009, 03:10 PM   #185
any test under halogen light? ;)
Marlon Martins is offline   Reply With Quote
Old May 28th, 2009, 03:17 PM   #186
Leonard, what about the loss of light induced by this filter? Is it still about half a stop? Or did Tiffen manage to reduce it?
Brian Cassar is offline   Reply With Quote
Old May 28th, 2009, 05:25 PM   #187
external or internal ND's - same
Yes 1/2 stop , but who knows what the final version will be.
Old May 28th, 2009, 06:32 PM   #188
Leonard, does Tiffen's filter produce a green halo around the edges of the frame at the wide end of the lens? (B+W does a bit).
Alex Raskin is offline   Reply With Quote
Old May 28th, 2009, 08:19 PM   #189
No, That is the significance of a dye based filter.
Old May 28th, 2009, 08:28 PM   #190
Thanks Leonard, Good news
I'm anxiously awaiting to pay $50 for this in 4X4 :)
Ed Kukla is offline   Reply With Quote
Old May 28th, 2009, 08:32 PM   #191
Maybe Ryan will take back my 486? ;-)
Old May 28th, 2009, 10:50 PM   #192
Leonard,
I'm still a little confused.... I have understood that the Tiffen IRND filters had a specific amount of dye based on the ND level of the filter.
If the new Tiffen filter coming out without ND works with regular (non-IRND) ND filters, why is it that the IRND filters could not be combined with regular ND filters before? Is this a totally new approach?
Art says in his article that the Tiffen filter can only be used with IRND ND filters, but that it surprisingly did appear to work with the internal NDs in the camera which baffled him. He says it shouldn't work like that....
I continue to be baffled.....
www.zooprax.com
Derek Reich is offline   Reply With Quote
Old May 29th, 2009, 01:33 AM   #193
Yes.
We've been looking at lots of filters with the EX-1 and much of what Art initially said was based on assuming it was similar to other Sony's. We found though that the Tiffen IRND's had no effect on the EX-1 .
This whole business has been confusing and each camera has been different.
The new Tiffen filter seems to work extremely well and simplifies the issue on the Ex-1 . I'm not sure yet what role it play with other cameras. I hope they come out with a production version soon.
Old May 29th, 2009, 03:48 AM   #194
Lenny,
Are Tiffen going to supply it as a screw-on, or 4x5.25", or both?
Old May 29th, 2009, 08:01 AM   #195
Yes.
I'll eagerly await the release..... this truly does sound like the 'holy grail' of filters if it can indeed be used with regular NDs!
www.zooprax.com
