720p playback Problems in Rec Review at DVinfo.net
Old January 29th, 2009, 11:14 AM   #1
I recently sent in my EX1 for firmware update to 1.11 and now have problems playing back 720p footage in Rec Review on Camera mode. Has any else noticed that problem?
In 1080p, it plays back fine. Also, in media mode it plays back fine. I talked to a couple of guys working at the Sony facility in NJ where I had the firmware updated, they have the same problems with their cameras. They told me that the problem had been sent off to some where else and they will call me back when they find out something.
Khang Mai is offline   Reply With Quote
Old January 29th, 2009, 01:15 PM   #2
Very strange, I have been 1.11 for some time now. Upgraded myself. I have no issues with 720p rec. review. I will have to double check 720p normal framerate because I only use 720p overcranked to 60 for slo mo and am 1080p most of the time and it works with no issues. I will check it tonight but with so many of us on 1.11 now I assume we would have heard from a lot of folks by now. Maybe the upgrade did not go smooth, I have heard others have some very strange issues if the firmware upgrade somehow was corrupted or such...
Jason Bodnar is offline   Reply With Quote
Old January 29th, 2009, 01:39 PM   #3
You would have noticed the problem on your camera if you played back any 720p footage in Camera mode.
Yeah, I thought there would be a thread on this issue but wasn't able to find one. I wonder if I should do the update myself this time instead of sending it back in. The Sony repair shop in NJ had the same problem as me so I wonder if it's something on their end.
Old January 29th, 2009, 05:47 PM   #4
Sounds very suspicious on their end. Maybe they are not following everystep of the process or somthing, however others have sent there Camera to them with no issues, Maybe a new tech, don't know. It really is very simple and if you follow the instructions you should be good to go in 15 minutes or so, just do it your self and rule out a corupt upgrade. Just make sure your connections and Power are solid...You could also try a factory reset first...But save any custom profiles if you have any becuase they may be wiped out.
Old January 29th, 2009, 09:14 PM   #5
I had a "funky" firmware upgrade from NJ. In my case though I couldn't playback any clips in camera at all when SDI out was enabled. Now that didn't make any sense at all. I brought the camera back to Sony NJ, did the firmware upgrade again while I waited. It's been fine since.
Old January 30th, 2009, 11:22 PM   #6
That happened to me to. I complained to sony about it and they fixed the 1080p rec review but the 720 still is jumpy. I'm out of warranty now, so i'm just dealing with it.
Winston Ashley is offline   Reply With Quote
Old March 21st, 2009, 09:29 PM   #7
I can verify that I just found I have this problem with my EX1, too. I don't usually shoot 720p unless I'm overcranking. I can verify that in the past I have had no problems with REC REVIEW playing 60fps overcranks material at 24fps, but just today when shooting 24fps without any over/undercranking it played back footage skipping lots of frames so it is very choppy. I'd love to find a solution. Anyone have any ideas? Playback works fine in media mode.
Noah Yuan-Vogel is offline   Reply
