#31 | |
isnt that where the interval record comes into play? I know over and under crank is limited for timelapse options, but when you start playing in the interval record menu, you get a lot of options. |
#32 |
Andy the small ones (inverters) don't draw much, but hopefully they have two trucks? One could jump the other. Or they also sell batteries used to jump start cars. You could also use the jump start battery to power the ex camera..
Those usually have a light and air compressor built in too. Just throwing out ideas.
EX3, Q6600 Quad core PC - Vista 64, Vegas 8.1 64bit, SR11 b-cam |
#33 |
Aye, the one I have has 18aH battery, silly LED work light, air compressor, inverter and even a USB power jack.
Andy Tejral Railroad Videographer |
#34 |
what if you start the car every so often? let it run for a bit to keep the charge built up. I know with my truck you can start and stop the engine and it wont affect the power output through an inverter. but I am also fortunate enough to have two batteries so i dont have to worry about it too much. AND if you have a manual, you can always push start it! hahaha.
#35 | |
And starting is a huge drain on the battery--you're better off leaving the car running. Certainly doable--on a certain September day in 2001, I ran a camera and microwave off of my car for hours but that is an expensive generator.
#36 | |
no, sold that before i left AK. had the 4runner for a bit, then moved to a dodge ram 2500 with a cummins. hence the two batteries. but your right, it would be better just to let it run all day (not environmentally friendly, but in a pinch). I remember the toyota's did disrupt the power, which is why I checked on my truck. its really nice to have. I still need to get a big inverter though so I can run lights for standups at remote locations every now and then. |
#37 |
Thanks for that Bob, I have looked this up now and it seems like the only way to do what I want.
#38 | ||
On EX timelapse not being 'industrial strength'...
and when using a stills camera for timelapse... Quote:
But don't get me wrong. I'm ALWAYS using the timelapse & slow shutter modes of my EX1 and it's one of the biggest reasons for going EX for me.
Director/Editor - MDMA Ltd: Write, Shoot, Edit, Publish - mattdavis.pro EX1 x2, C100 --> FCPX & PPro6 |
#39 | ||
#40 |
I did a very short TL using Quicktime and my old Nikon Coolpix 990 seen here:
Twilight timelapse on Vimeo Very easy to do and I'm much prefer having this camera (or similar) tied up on a job instead of my EX1. |
#41 | |
I'll start with a couple of the intro shots to 'Winners Circle' - third one down on http://www.mdma.tv/cb but I have PMed you with something which will soon be up. When I get a chance (have been planning this since last August) I'll be putting together my showreel which will have oodles of under and over crank stuff. Sorry, but so often in event video, almost all of the content is private and until I do a showreel, can't get the time to separate showable shots (mostly the timelapse stuff) from unshowable content. PS: Sorry - forgot to hit 'submit reply'...
#42 |
[QUOTE=Matt Daviss;998417]At some point, one has to consider doing timelapse the old fashioned way - with a DSLR. Plenty of little magic boxes to run them off car batteries, take images when something happens, be out in the open for weeks or months in locked down enclosures and so on.
A couple of things to note: DSLRs can work in raw mode, which means exposure variation and white balance can be sorted out in post, and that most shoot at a high enough resolution that - with a good wide - you can do some pan & scan work even at 1080p with resolution to spare. How do you do the pan and scan work? Is this in After Effects? I'm OK as far far as preparing all the images from a DLSR but couldn't find the function for panning across the frame. Thanks Andy |
#43 |
Dave: How did you do the actual timelapse? Digisnap?
I actually have a 4500 and a DigiSnap (alas, the digisnap seems to have died). It is a great way to go. What I don't like about is the programming: it is easy enough to do and certainly is very flexible in what it can do but the need for a computer with a serial port is a bummer. I never got it to work with the usb/serial dohickey. I've actually regressed a bit. I'm now using a Canon A10 with a laptop running Canon's remote capture. Much less flexible than Digisnap but is very easy to set up. Here is one I did with this setup: Tide goes out The downside to both of these is the wires. You need to supply power to the camera and laptop or make sure the digisnap has adequate power. Then tether the camera to the TL device. That's why I'm interested in the EX/HPX solution. Hooking up an external battery is not a big deal for me--that can just sit under the tripod. But the idea of having the TL being done by the camera is a winner for me. And Dave, I guess I'm not sure that that method of raw processing would be worth the hassle. I've done both auto and manual exposure controls and both seem to result in flash frames due to lighting changes. If you could do keyframing on individual raws, that would be something. And I'm still trying to come up with a joke regarding 'mdma'. I hope your clients are in ecstacy?
#44 | |
I believe you can do the same thing in Vegas as well.
#45 | |||
Yes, an older Digisnap 2000, IIRC.
