SDHC Brands that work with MxR - Page 3 at DVinfo.net
Old July 24th, 2009, 02:10 PM   #31
I'm using Silicon Power Class 6 16gb cards. no problem whatsoever.
o don't do overcrank, and also after "pause" a recording, must wait about 4 seconds to record again, or will give the classic "media need to be restored"
im using a realtek-based card reader, unload 16gb in 15-16minutes.
Marlon Martins is offline   Reply With Quote
Old July 24th, 2009, 03:16 PM   #32
Sandisk are no longer reliable. They've changed their manufacturing process. I've been using 32GB Class 2 Sandisk cards since January and NEVER had a problem. People have been complaining about Sandisk Since February so it seems.
Transcend SHDC Class 6 cards are now "the" reliable card although like the above person people are finding other viable cards as well.
Old July 24th, 2009, 04:29 PM   #33
my friend Gabriel Soares got the silicon power first, i believe due to tests made:
Charts, benchmarks SDHC Memory Card Charts, Minimum Write Transfer Rates
as it worked fine for him, i bought also ;)
transcend are quite hard to find from a reliable source here, and silicon power are cheap ;)
Old July 24th, 2009, 04:41 PM   #34
I just bought 8 Transcend class 6 cards from Amazon (not a third party) and checked Serial #s. They are plagued with "Media Restore" problems. So I'm not sure I'd call them reliable anymore. Quite frankly I don't know if there are any reliable cards right now. Something seems to have happened to the SDHC supply.
Brett Sherman is offline   Reply With Quote
Old July 24th, 2009, 07:32 PM   #35
Originally Posted by Scott Ippolito View Post
Hello Everyone,
I'm wondering if anyone else has experienced any problems with the MxR and SanDisk cards. I've had the cards for a few months now, and I have now had my third major problem.
The first incident occurred while shooting on a reality television show. The card showed no problems during shooting (I never got the Restore Media message), but when I tried to import on a MacBook it was unreadable. I tried several data restoration programs, and went so far as to have the Geek Squad take a look. Unfortunately, there were no salvageable files. I contacted Sony to see if they might be able to help, but obviously because it is a third party product they were unwilling. This was a pretty big disaster and although we did not lose a lot of footage in did cost me a client.
I talked with Ross from eFilm and he deduced that most likely it was a faulty SanDisk card. This seemed plausible to me, but the part that bothered me was that I had used the card successfully for a couple of weeks before the failure.
Currently, I am in Rwanda shooting a documentary. Last week I had another card fail. This time the card did appear in the XDCAM Transfer but several clips were corrupted. They each played for a few seconds, but would always stop at the same point. Once again it seemed plausible that the card simply had a bad sector or two. Still, I was bothered because it was a card I had been using for several weeks without a problem. I immediately took this card out of my usage rotation.
Today, I have had yet another problem. The card is readable in the XDCAM transfer program, except for a 17 minute interview clip. (Unfortunately, this is a one time only interview with a convicted murderer/perpetrator of the '94 Genocide here in Rwanda). When I try to import the clip it goes to 87 percent complete and suddenly ejects the card.
Because the clip is visible and plays partially I'm hoping that it is salvageable to some extent. When I insert the card in the camera it gives me the Media Restore message but the restore fails at 22% every time.
The failures have occurred on three separate SanDisk Ultra II Class 4 16GB cards purchased at separate times at separate retailers. I have a few Sony SxS cards that I use as well and I have never had a problem with them so I'm certain the camera is fine.
I don't feel like the MxR is necessarily to blame. However, I'm beginning to feel that if it is possible to use the SD cards recommended by the makers of the MxR and still have these types of problems I don't see how the MxR can be suitable for professional use. As I said before these were cards that I've been using for some time. Each time I've purchased an SD card I have set the camera up and recorded through the entire card TWICE and transferred these clips to insure there would be no hidden problems.
At this point, I have lost all faith in the MxR's viability for professional use. Even if the problem is with the SD cards I don't see how the work flow can be usable in a professional environment. The real issue as I see it, is that these cards have failed after several dozen successful uses. If they had simply failed out of the box, upon testing, I would be more convinced of the MxR's viability.
Previously, I owned an HVX200 which I used to shoot extensively throughout Asia and Africa and I never lost a single clip. The MxR was a big factor in switching to the EX1 (not to mention the sweet resolution). At this point I'm pulling all of the MxR cards out of usage and ordering additional Sony SxS cards and having them overnighted from the US.
I'm extremely curious if anyone else had had any problems like this. I'm open to any suggestions for salvaging my latest card.
Scott
I am curious - was it your practice to leave the cards in the same MxR adaptors or take them out for downloading into the computer and then reinsert them into the adaptor?
Barry J. Weckesser is offline   Reply With Quote
Old July 24th, 2009, 08:01 PM   #36
I'm not Scott but I've been using 2 32GB Sandisk Ultra II CLASS 2 (not 4) cards since January without issue. I always take them out of the MxRs and us SDHC to USB reader.
It seems shortly after January Sandisk changed something about the cards and the new cards seem to be CLASS 4 and some have reported them problematic.
Old July 25th, 2009, 06:06 AM   #37
My point was that I have seen some posts on here where people had problems when they were constantly taking out and reinserting cards into the adaptors (perhaps bending the contact areas). A number of people (myself included) put the cards into the adaptors and never take them out - using an express-card-USB adaptor to download.
Old July 25th, 2009, 06:08 AM   #38
I just wanted to point out that I have been taking them out of the adaptors to transfer for nearly 7 months no and not even one single issue ever.
Note that using Clip Browser is the way to go. If you drag and drop it is possible for the OS to write back invisible files which may result in a media restore since these files are outside of the expected file structure.
Old December 7th, 2009, 02:44 AM   #39
brand
Hi,
my friend has an EX1 (latest firmware) with MxR adapter and with 2 Sandisk Ultra II 16GB card (class 4).
One of them has produced "media need restore" message in the first usage after few minutes, the other worked perfectly over many hour. He work in 1920x1080@60i at 35Mbps.
He call me just now, that the cards doesnt work anymore. He even cannot format, and use it like before. How can this be?
So our questions:
- in the first time why need one card media restore and not the other? isn't the two card the same?
- WHY is this media restore when so many people recommend this brand and ultra II speed?
(spec. was 15MB/sec, but maybe its just for reading speed?)
- 35Mbps is just AVERAGE bitrate, and when he pan quickly maybe this bitrate will go over 40-50Mbps, and then he got the error message?
- can we kill these cards only because writing for long time at 30-40Mbps?
What do you recommend now? A class 6 card doesnt have this error? He like to do wedding videos, no overcrank, just SAFETY recording in 1080@60i.
thx,
Marton
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply With Quote
Old December 7th, 2009, 03:13 AM   #40
Originally Posted by Prech Marton View Post
Hi,
People did recommend the Sandisk cards. However that was a while ago and according to the MxM website there have been inconsistencies reported since then.
The card you want is the ATP Pro Max.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old December 7th, 2009, 08:05 AM   #41
It seems Sandisk changed their manufacturing specs many months ago. Since then the cards have been inconsistent. The 32GB Sandisk Ultra II cards I bought last January have been flawless for me. If I were to buy as 32GB card today it would be the ATP ProMax cards. It's what MxM recommends.
Old December 7th, 2009, 08:08 AM   #42
unfortunatly we cannot buy this brand in Hungary.
Maybe Transcend class6 worth a try?
www.3d-video.hu
Old December 7th, 2009, 09:07 AM   #43
As I've detailed elsewhere, I ordered an ATP from MxM in Australia and it was with me quicker than one of my UK suppliers would deliver!
You can chance your arm with the Trancends, but there is a very good reason why my 6 cards are all sitting in storage rather than in adaptors. You might be alright, or you might get a bad card. Is that a risk you consider worth taking? I don't.
Marcus Durham
Old July 2nd, 2010, 12:22 PM   #44
SDHC cards and Kensington adapters
In response to Scott, I have been using SDHC Class 6 Transcends and Sandisk Ultra II's for a long time on my EX3. Then my friend got some class 4 Sandisks (from B&H as well, because we avoid dodgy retailers) and what do you know, one of them failed on the field, had to re shoot the days work.
I would like to know if there is any combination which does work.
Saraswati Films | Krishna
Film is the New Pen TM
Blackmagic Cinema Camera, Sony PMW EX3, 5D, 7D, HVR A-1, ME66/K6, Editing Studio, FCS 2
Film is the New Pen
Manish Pandit is offline   Reply With Quote
Old July 2nd, 2010, 01:03 PM   #45
Manish, firmware makes a lot of the difference. EX1 with 1.2 will handle SDHC that 1.11 will not. I think the safest bet is to go with the new Sandisk Extreme Class 10. ATP Class 6 cards have a good reputation as well. I would NOT use Transcend especially if you're not on the latest firmware. Also Sandisk other that the current Extreme seems to be hit and miss with some people.
I'm using EX1 firmware 1.11 with Sandisk Ultra II Class 2 cards (yes, Class 2) and they have been flawless for 18 months and counting. You can not get those cards anymore. Seems they were only around for a few weeks before Ultra II Class 4 came out which were problems.
Generally though EX1 firmware 1.2 has resolved most of the SDHC issues although nothing can help poor QC from a card maker though.
Craig Seeman is offline   Reply
