Sony Log & Transfer Utility for Apple FCP? at DVinfo.net
Old December 31st, 2008, 11:42 AM   #1
Anyone used this yet? Is it easier/faster to use than XDCAM Transfer? Here's what I found on the Sony site:
Sony | Micro Site - XDCAM EX
Log and Transfer Utility for Apple FCP Version 1.00
The Log and Transfer plug in software utility for XDCAM EX allows any resolution of current XDCAM EX file to be easily imported within FCP using the standard Log and Transfer interface within FCP.
Works with Apple Tiger /Leopard Operating System (Mac OS X Ver10.4.11 or later) also requires FCP 6.03 or later.
Instructions:
1) Create a new folder to copy dmg file to.
2) Copy file to your Mac.
3) Double click on the icon in the folder you have created.
4) Installer will launch. Follow the installation instructions.
5) Use the Log and transfer window to ingest EX files into FCP.
NOTE: XDCAM Transfer has the following advantages over Log and Transfer
Support both XDCAM EX & XDCAM Disc
Handles XDCAM EX and XDCAM Disc clips
mounting SxS & PD media at the same time
MXF export capability
Can write edited material back to Professional Disc in MXF files
Standalone browser/viewer
Browsing/viewing are possible without running Final Cut Pro
Other benefits
Full-screen playback
Cache functionThumbnail information available even after ejecting the media
Can create multiple sub clips by Mark In/Out
Log and Transfer has the advantage of working directly within the standard Log and Transfer interface within FCP
Click here to download the software
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply With Quote
Old December 31st, 2008, 02:32 PM   #2
I've used it. It works. I prefer XDCAM Transfer Tool so that's what I use.
Old December 31st, 2008, 04:08 PM   #3
Better than Halle Berry
It does essentially the same task- though ignoring most of the metadata- if that's a key part of your workflow. It's a bit more straightforward if you're used to working all within FCP too. I
Noah
Noah Kadner is offline   Reply With Quote
Old December 31st, 2008, 04:16 PM   #4
From watching the Vortex Media EX3 training dvd I learned the difference between the Clip Browser and XDCAM Transfer is that Clip Browser won't unwrap the footage and rewrap it into a QT movie for FCP. Also XDCAM Transfer will allow you to create sub clips so you don't have to import every clip in it's entirety.
Does Log and Capture do all that? (is it the same as FCP Log & Capture that I've used for years with DV tape....but with SxS thumbnails?)
Old December 31st, 2008, 04:39 PM   #5
yes it's the same. All it does is cause the Log and Transfer window to be able to open and ingest from BPAV folders. It's nothing super amazing. :)
Noah
Old December 31st, 2008, 05:18 PM   #6
So then why would people still choose to launch another program (XDCAM Transfer) when they can do it all within FCP? Can you set in/out points with Log & Capture?
Old January 1st, 2009, 12:02 PM   #7
You can set in and out points in Log and Capture (and in XDCAM Transfer).
I prefer to use Log and Capture for two reasons.
1) I can capture Audio Only or Video Only using L&T. Obviously, Audio Only saves an enormous amount of disk space and there's no way to do it using XDCAM Transfer.
2) When you log a clip with L&Transfer, you can play it back "In" to "Out" - frame perfect. That's very important to me - especially when capturing Audio without Video as there's nothing to see. XDCAM Transfer only allows you to play back from the "In" point. When it reaches the "Out" it just keeps playing.
I also prefer the way that L&T numbers clips - but that's probably not a valid point as I don't understand what XDCAM Transfer's numbering system is about.
I taught you all I know and still you know nothing.
Andy Nickless is offline   Reply With Quote
Old January 1st, 2009, 12:13 PM   #8
Thanks for the reply Andy. Good information! (I capture audio only sometimes too)
Old January 1st, 2009, 03:37 PM   #9
Why do people eat chicken instead of beef? Matter of preference or who knows...
Noah
Old January 1st, 2009, 04:04 PM   #10
Got it. Thanks! :)
Old January 3rd, 2009, 09:35 AM   #11
XDCAM Transfer is great for neatly named rushes
There's a GREAT reason for using XDCAM Transfer over Log and Capture.
In a nutshell, neatly labelled rushes with embedded metadata readable within your source QuickTime movies when you do a Media Managed copy.
I tried explaining it, didn't work, so I made a movie about it:
Batch naming clips in XDCAM Transfer on Vimeo
My first screencast, so sorry about the 'bumpiness' and the obvious bloopers. But the info is there.
EX1 x2, C100 --> FCPX & PPro6
Old January 3rd, 2009, 12:22 PM   #12
Great job Matt! Very well done screen cast! You've got some very good points in there about why we should all be using XDCAM Transfer. Especially interesting info about ShotPut Pro. Imagine Products Inc. - Home of Video Logging, Archive and Enhancement Applications ($89)
Thanks for taking the time to do it. Hopefully you'll produce more of them.
Old January 3rd, 2009, 02:07 PM   #13
Excellent Presentation, Matt - thanks!
Thanks for the presentation Matt - very professionally put over.
I'd like to put my hand up and speak out for Log and Transfer though!
Please don't misunderstand, I think both are useful, but for me, "L & T beats XDCAM Transfer on precision alone.
As I said in my previous post on this thread, "L & T" has the ability to play "In-to-Out" when you are logging clips - extremely useful at times.
Transfer has the advantage as far as batch naming is concerned - but if you give subclips separate names, you have to capture each one individually. With "L & T" you can simply send them to the Log Queue and Ingest when you're ready. (I prefer to do them in batches as the Ingest process seems to interfere with the preview when I'm logging the next clip).
When it comes to Logging info, "L & T" beats "Transfer" I think, because you can log all of the following individually:
Reel
Clip Name
Scene
Shot / Take
Angle
Log Note
ALL of these notes and names appear next to the clip in FCP - and when logging in "L & T", ALL have drop-down menus of previous log info you've used, so the log process couldn't really be quicker.
But what puzzles me is why you don't use Clip Browser if you have a MacBook?
I know nothing of Clip Browser as I have a G5 PPC but I rather got the impression Clip Browser was "The Business"?
Old January 3rd, 2009, 02:35 PM   #14
Originally Posted by Andy Nickless View Post
  • Reel
  • Clip Name
  • Scene
  • Shot / Take
  • Angle
  • Log Note
Ah yes. We're all shooters here, but some are artillery, some are snipers and some just spray in a certain direction (erm, guilty) - I'm afraid I don't tend to do scenes, takes and angles - but log notes go in Transfer. And quite often, that happens in the field (though NOT the transfer, funnily enough - that happens when I want it to).
Shooting more scripted or controlled stuff and dare I say 'briefed' interviews may mean that the precision of L&T is appreciated more.
But what puzzles me is why you don't use Clip Browser if you have a MacBook? I know nothing of Clip Browser as I have a G5 PPC but I rather got the impression Clip Browser was "The Business"?
I tried it, and found certain features fun and quite possibly useful, but the workflow I have with XDCAM Transfer is just a perfect fit with what I do (corporate 'mini docco' and event (aka conference) video) that I will find it really hard to switch to anything else out there.
Such work involves rather high shooting ratios, and buried within takes are those little gems that make a production soar. I therefore throw away rubbish but don't set in and outs or split clips in Transfer.
I do all of that in Final Cut (I'm doing that right now). I've got sequences of each interview, with good bits chopped out. I copy good bits from each interview and copy those into separate 'subject' sequences. Therefore I need neatly, consistently named clips and I need metadata such as tummy-tag info (name, position, company, location) still embedded into the clips so when I'm doing captions at 0300, I can copy and paste, not look in log notes.
It's all possible because of Transfer - batch name, embed text info into each clip. Egad, had a funny turn, remembered 'tape'... <shudder>
Old January 4th, 2009, 08:01 AM   #15
The question I have about the workflows is what happens after the project goes offline and you need to do revisions or repurpose offline sections some time later?
If Clip Names don't match source file names I'd think there'd be a problem. FCP timeline would look for the MOV files. Are both of you backing up the MOV files in addition to the BPAV?
In my case I make sure the BPAV names remain the same for MOV (I backup BPAV). I then add descriptions in the note fields. I don't touch the clip name.
Craig Seeman is offline   Reply
