Camera strap for Ex1 at DVinfo.net
Old December 17th, 2008, 10:00 PM   #1
Anyone have suggestions for a Camera strap, one that leaves the hooks on the camera, permanently and then when you attach the strap its very quick to clip on, checked out the following on B&H.
Would appreciate any thoughts, thanks.
Porta Brace | HB-12DV CAM Mini DV Camera Strap | HB-12DVCAM
Chris Paporakis is offline   Reply With Quote
Old December 20th, 2008, 10:34 AM   #2
I have this strap...I think?
I bought it or similar years ago, it came with plastic snap clips on the ends.
I use it all the time on my EX3, climbing up ladders and alike.
To connect it to the EX3 I got some Black Codura/Nylon strap material off an old stills camera strap, and stitched it permantly onto the EX3 into a loop using fishing line.
The loops are soft and do not make a noise on the camera when the strap is off.
Mark Twittey is offline   Reply With Quote
Old December 20th, 2008, 11:52 AM   #3
I have this one two cameras and love it!
Pro Camera Gear
Curtis Edwards is offline   Reply With Quote
Old December 20th, 2008, 12:18 PM   #4
porta brace
I have the same one you referenced in the original post, however it has silver metal buckles. Works well and you leave the hoops on the cam... easy on and off.
Greg
Greg Chisholm is offline   Reply With Quote
Old December 22nd, 2008, 02:49 AM   #5
Thanks for the replies, I think will go for the porta brace one,
it looks comfortable enough :-)
