Thread Tools
Search this Thread
Need help viewing clips on Panasonic BT-LH900A monitor
Over the weekend i was shooting with my EX1 while using the Panasonic BT-LH900A monitor. i was having an issue with playback on the monitor. the monitor's image was split in two when viewing playback and live viewing when the 24P System was set to 60i in the Video Set menu. as soon as i switched to 24PsF the image was fine during live viewing. the real problem i had was with playback. it was fine when i executed the Rec Review feature on the grip handle, but when the camera was in Media mode the image was skewed once again. it looked like the left third side of the frame was moved to the end of the right edge of frame with a solid black bar seperating the split image. so, how is it possible to view the image correctly when in Media mode????????
fyi: i was recording 1080/24P to the SxS cards. the monitor was connected to the HD/SDI port. thanks in advance. |
Buehler, Buehler??? anyone???
I think you just have the monitor in a split freeze mode. It's for matching for stop motion or something, just keep going though the monitors menus.
