4.3 mode ... at DVinfo.net
Old November 23rd, 2008, 04:46 PM   #1
4.3 mode ...
I heard that the EX1/3 will shoot 4.3 in standard mode via s-video and analog audio connects. Is this true?
Dean Harrington is offline   Reply With Quote
Old November 23rd, 2008, 05:05 PM   #2
The EX1 will not shoot (record) in SD, it only records in HD which is 16:9. You can downconvert the camera recorded output as an SD signal that can be cropped to 4:3.
Bob Willis is offline   Reply With Quote
Old November 23rd, 2008, 05:10 PM   #3
I wouldn't have thought so. It doesn't have an s-video connector. It has component and composite output.
The manual states that the video format selected from the recording menu wil also be used for output over component and composite. None of those formats are 4:3. You can have a 4:3 frame on the LCD to help with composition but that's all.
Ian
Ian Briscoe is offline   Reply With Quote
Old November 23rd, 2008, 05:33 PM   #4
You can set the Video Set/Down Converter menu setting to Edge Crop, which gives a 4:3 SD signal by discarding the edges of the 16:9 frame.
Nick
Nick Wilson is offline   Reply With Quote
Old November 23rd, 2008, 05:44 PM   #5
S-video ...
Ian
I'm looking at the S-Video connector on the back bottom right side of the camera (EX3) next to monitor out.
Old November 23rd, 2008, 06:18 PM   #6
Yes, Dean, it's there. You can connect the camera to a monitor or television that has an S-video input. However, neither the output nor the image will be in SD or 4:3.
The down conversion is best handled by your NLE.
Jay Gladwell is offline   Reply With Quote
Old November 23rd, 2008, 07:11 PM   #7
thanks guys ...
I'll mull this over and play with it.
Old November 23rd, 2008, 07:15 PM   #8
Actually the Sony XDCAM Browser will down convert the footage too.
JB
Jose Bucaro is offline   Reply With Quote
Old November 23rd, 2008, 08:09 PM   #9
s-video ...
Nick
I'll try this via DRS 11 and see what happens.
Old November 23rd, 2008, 10:42 PM   #10
I have no idea about the EX1 but the EX3 does output in SD and you can centre cut the image to give a 4x3 picture. As I mentioned in another thread, I found the composite image to be less than acceptable.
David Issko
Edit 1 Video Productions
David Issko is offline   Reply With Quote
Old November 24th, 2008, 03:44 AM   #11
Apologies - I didn't read the "/3" part of the post. The EX3 does have s-video, the EX1 doesn't.
Ian
Old November 24th, 2008, 06:51 AM   #12
David, would you, please, provide the documentation on that?
Old November 24th, 2008, 08:33 AM   #13
Ian
Actually the EX-1 does have s-video output if you use the correct cable. It looks like the composite cable but with an extra doo-dad on it that's an s-video jack. It's sony part #182315613
Ronn Kilby is offline   Reply With Quote
Old November 25th, 2008, 05:30 AM   #14
Hi Jay,
I don't have my camera to hand but from memory, you can set the composite (& S-video) output via the menu (of course - is there any other way!!!!) to give the standard SD downconverts such as squeeze, & crop etc.
Was that what you were after? I haven't tried the S output to compare its quality to the composite. Anyone compared the o/ps on the EX3?
Hope this helps you.
Best wishes
David Issko
David Issko
