Working Combo: EX1 + MRC1 ? at DVinfo.net
Old November 10th, 2008, 05:01 AM   #1
Asking just out of curiousity: Has anyone ever tried to match the Sony HVR-MRC1K CF Card recorder with an EX 1 in SP mode?
The MRC1 makes the Sony Z5, Z7 and Z270 capable to enjoy flash memory recording instead of tape or harddisk recording. It is said to work with various other HDV cameras as well, also non-Sony. Connection is achieved through a standard firewire cable and, yes, the recorder records in sync with the start/stop of the camera.
With the MRC1 at appr. 630€ + VAT, it is less expensive then a 16GB SxS Card it might be an interesting alternative for users with an HDV camera and an EX1 to SDHC or SxS flash memory recording.
Any thoughts?
Link to MRC1: Sony Product Detail Page - HVRMRC1K
Peter Kraft is offline   Reply With Quote
Old November 10th, 2008, 07:28 PM   #2
I'm not sure how you would do this. The EX-1 doesn't have a firewire port.
Kevin Walsh is offline   Reply With Quote
Old November 10th, 2008, 07:39 PM   #3
Uhhhh it sure does.
Jon Sands is offline   Reply With Quote
Old November 10th, 2008, 07:58 PM   #4
Oops, sorry about that. I forgot iLink was Sony's name for firewire.
Old November 10th, 2008, 08:18 PM   #5
As penance I just hooked up my HVR-MRC1 to the EX-1 and it seems to work fine. You can trigger the MRC1 from the camera, a little lag when recording to SXS at the same time, but no lag when going straight to the CF only.
Old November 11th, 2008, 06:34 AM   #6
Kevin,
thank you so much. Highly appreciated. Just wanted to make sure I can use SxS 8GB for normal work and a BIG 32 or 64CF in case if extra long takes are a nesessity (meetings, key events and so forth). SxS/16GB and 32GB would be too expensive for that kind of customers who tend to ask for "the original" at the end of the day.
While SDHC might help to achieve the same result, I do not have enough confidence yet in such "un-official" workflows.
Thanx again. Pe.
Old November 11th, 2008, 11:06 AM   #7
Which CF card did you try? I see (link below) some "QMemory" brand 32GB cards for $99 and SanDisk Extreme III 16GB for $150. Wondering if the cheaper cards will work.
Compact Flash Cards, CompactFlash Cards, CF Cards
Ronn Kilby is offline   Reply With Quote
Old November 11th, 2008, 11:50 AM   #8
I must point out that for 630 euros you could buy 250GB of SDHC memory and a couple of Kensington Adapters, as well as record to HQ.
The SDHC combo is well tested and totally reliable, I've stopped using my SxS cards except for overcranking, I'm about to sell my 16gb SxS as its of no use to me at all, I'm carrying 12, 16gb Ultra II's in my camera bag, around 12 hours of HQ recording !
I fully understand wanting to record SP to 32GB CF cards, great for conferences and the like, and cool to pass to the client at the end of a shoot, as with SDHC.
Paul
Another Sunny Day in Ibiza
Paul Newman is offline   Reply With Quote
Old November 11th, 2008, 08:54 PM   #9
I used a Transcend 16GB 300x. I have had a lot of problems with cards slower than 300x. (133x and 150X)
