EX1 infrared contamination: myth or reality? at DVinfo.net
Old October 12th, 2008, 04:17 PM   #1
I have tested a B+W IR filter 486 with EX1, and could not see any difference in the image with vs. without the filter.
What practical situations lead to IR contamination? (screen shots illustrating IR filter saving the day would be most helpful...)
Alex Raskin is offline   Reply With Quote
Old October 12th, 2008, 04:36 PM   #2
Please see my post in the Red Problem thread:
http://www.dvinfo.net/conf/862316-post113.html
Old October 12th, 2008, 05:16 PM   #3
Piotr, would you be so kind as to re-state:
1. under what circumstances does the IR problem occur
2. what are advantages/disadvantages of using filter
3. any alternative solutions?
(The thread you referred to is huge, I'd really appreciate your digest...)
In my own tests:
1. I actually have not seen the problem yet. I'm shooting under fluorescent and LED lights, or natural sunlight, mainly.
2. 486 filter made everything greenish, which looked bad to me
3. ?
Old October 12th, 2008, 06:58 PM   #4
Found this:
ProVideo Coalition.com: Camera Log by Adam Wilt | Founder | Pro Cameras, HDV Camera, HD Camera, Sony, Panasonic, JVC, RED, Video Camera Reviews
Dramatic example of EX1 rendering black shirt as brown; and 486 filter fixing the problem.
So all the reading I've done so far points out to the answer: "IR contamination - it depends... Have 486 filter handy just in case."
Is that a consensus?
Old October 13th, 2008, 01:25 AM   #5
Alex,
Yes, Adam Wilt's description of the problem is accurate. I'd add some points from my experience:
- the problems is most pronounced in tungsten light, and with clothes, fabrics etc. of certain colours (mainly black or dark blue)
- using the 486 filter is only recommended as the first optical element as it reflects IR, hence it's no good to be put between the camera lens and a 35mm adapter for example. Also, at the widest lens setting, the ugly green cast is visible at the image extremities (especially left and right edge)
- the 489 filter is supposed to absorb IR, so it doesn't have the limitations of the 486; it also produces the side effects though
- Schneider Optics claim their 750 nm filters do not produce the green cast; I haven't tried them yet
- Is the colour change a real problem? Well, certainly when somebody notices the colour infidelity, it's a rather embarrassing situation for a pro CineAlta camera owner / operator... Also, inter-cutting between the EX and other cameras is extremely difficult if not impossible with material shot in tungsten light.
Old October 13th, 2008, 05:23 AM   #6
thanks Piotr...
I've read the entire thread you have referred me to, and it looks like True-Cut IR 750 is the ticket... do you know where to buy it in the US in 77mm version? (I don't think I'm ready for the matte box/4x4 at this point...)
Old October 13th, 2008, 06:36 AM   #7
Have no idea, Alex - but haven't looked for it, either. I have a microMatteBox on order, so I will be buying the 4x5.65" version some day (the 4x4" are reported to cause vignetting on the EX1).
Old October 13th, 2008, 06:45 AM   #8
Surely you are not buying RR matte box just to hold the IR filter? What other filters are you planning on using with this cam?
I own a quality circular polarizer that is absolutely necessary with surface reflections and sky shots; and I was planning to get a IR filter now. Both screw-on type.
Old October 13th, 2008, 06:50 AM   #9
Along the matte box, I'm buying a set of 4x5.65" filters from RedrockMicro: the polarizer, ND, and grad ND. I think I will be using them quite often; also the matte box seems rather essential with my SLR lenses I use with Letus.
Old October 13th, 2008, 07:24 AM   #10
Originally Posted by Alex Raskin View Post
thanks Piotr...
Doesn't appear to be available in a circular 77mm version, which is very unfortunate.
Jay Gladwell is offline   Reply With Quote
Old October 13th, 2008, 07:33 AM   #11
SLR w Letus: I mostly use the marvelous Zeiss 100mm macro, which has its own hood - so no matte box needed...
IR filter: I guess I'll stay with the 486 as a working option for now. At $167, it seems like a reasonable solution, comparing to $1,000 - $2,000 for matte box+filter... especially since the problem is relatively rare...
There's also a slim version of the 486 filter, which fits under EX1's stock lens shade.
Old October 13th, 2008, 09:33 AM   #12
Schneider Optics is planning a 77mm version of the True Cut IR 750; if it is not out yet it can't be long.
Try one of their resellers, like Abel Cine or B&H. You could even try PM-ing Ryan Avery of Schneider Optics for an update if you don't get anywhere with the resellers.
George/
George Kroonder is offline   Reply With Quote
Old October 13th, 2008, 09:40 AM   #13
George, I did email Ryan from this forum's contact form, no response yet.
Old October 13th, 2008, 09:45 AM   #14
Well, he's pretty active on the forum but that's not to say he hasn't got other matters to attend to. I'm sure he'll get back to you "eventually".
In the mean time, give Abel (or preferred supplier) a call and ask them for a projected delivery date. They may even already have a pre-order list.
George/
Old October 13th, 2008, 09:51 AM   #15
The IR issue is real.
I have been working with an testing the IR 750 for a couple of months. It makes a difference. I'll be featuring it in some upcoming writing and also will speaking about it next month in a session at an upcoming event in LA.
The 486 will give you a greenish cast.
Go with the 750
Ned Soltz is offline   Reply
