New strange image problem with my EX1 at DVinfo.net
Old October 7th, 2008, 08:30 AM   #1
I have had my camera since december and just discovered a problem I have never seen before:
Sometimes, quite often, there is a disturbance in the image. It looks very similar to the rolling effect when recording with a 50 fps shutter in 60 Hz lights. Only this happens outdoors in daylight.
Here you can see a clip:
Rolling shadow problem EX1 By Ola Christoffersson On ExposureRoom
I have not seen this before in the hundreds of hours of video I have recorded since I got the camera. It only showed up last week. Factors that could be involved here is my new Letus adapter and the fact that the camera has been to Sony for repairs and 1.11 firmware upgrade.
At first I though it was some kind of interference with my new Letus but to my big surprise it is still there when I take the Letus off.
It is coming and going and I cannot make out a typical scenario when it happens. It seems like it is starting after moving the camera or iris (maybe) and then settles down after a few seconds. I am not certain though!
I thought I'd ask you guys for help before I call Sony. Anyone seen anything like this? What could it be? Is the camera broken.
I should also add that it happens with shutter both on and off (180 degrees).
Ola Christoffersson is offline   Reply With Quote
Old October 7th, 2008, 08:42 AM   #2
Ola,
I'm not sure how ofter you're seeing this issue, but based on that footage I would send the camera in to Sony along with a CD that has an this example footage.
This looks like it's something to do with the CMOS rolling shutter.
Old October 7th, 2008, 08:57 AM   #3
A dumb question, but is the Motion Stabilization turned on when this happens?
Old October 7th, 2008, 09:09 AM   #4
Ola, this is what I was seeing in my brand new EX3 just a few days ago (I posted a question about it "Rolling Shadow"). You've described it (and shown it) perfectly!
To make a long story short, to fix another problem I wound up using the "All Reset" button in the Others menu. Since I've done that, the camera hasn't had that problem.
Hope this helps!
Jay Gladwell is offline   Reply With Quote
Old October 7th, 2008, 09:24 AM   #5
It is off.
Old October 7th, 2008, 09:25 AM   #6
Hope this helps!
That's very interesting. I will try that tomorrow! Thank you for your help.
Old October 7th, 2008, 09:54 AM   #7
Is the flicker reduction turned off? Depending on your region settings flicker reduction can cause flicker!
Old October 7th, 2008, 11:38 AM   #8
Ah!! That could be it. I believe it is on automatic. I have been experimenting with it when filming 60 Hz computer monitors recently so I might have changed it. I will check tomorrow and let you know if that is it...
Old October 7th, 2008, 08:21 PM   #9
Since I had this same problem, I took this issue over the Sony Vegas forum to see if anyone there had experienced this same problem.
One poster said the "rolling shutter" effect could be discounted because the illumination is constant. She said it looked like a defect in readout, possibly confirmed if the All Reset fixed it.
She also said electrical interference causes such effects (radars particularly, and mobile transmitters) -- that can be checked by it being location dependant (unless it's your cell phone).
Another poster wrote that he had this with his EX1, in daylight as well as under lights. He said that turning off Flicker Reduction in the Camera Menu seems to have cured it.
I contacted the dealer (Alpha Cine) and they are looking into it. They even went so far as to contact Sony. Will post the answer as soon as I get it.
Old October 7th, 2008, 09:03 PM   #10
Hope this helps!
May I know when you execute the "All Rest" button, will all the settings return to factory default? And will the profile setting be gone too?
Back to Ola's issue, I have also encountered this under indoor lighting, and my most recent encounter was during an outdoor shoot 2 weeks ago. As it was an imprtant shoot, I was panic and don't know what to do, then I quickly switched to full auto and the flickering went away. Switching back to manual mode and dod not see the flickering again. Strange!!
John Woo is offline   Reply With Quote
Old October 7th, 2008, 09:19 PM   #11
Actually indoor lighting is possible. We all know these CMOS rolling shutter based cameras can show this exact condition under older low-frequency fluorescent or HMI lights.
Old October 7th, 2008, 09:27 PM   #12
That could be it. Flicker reduction was designed for shooting under flourescent lighting (non-production, i.e. crappy). If you want to shoot computer monitors use the ECS shutter mode.
Adam Reuter is offline   Reply With Quote
Old October 7th, 2008, 09:47 PM   #13
Images: 3
Originally Posted by John Woo View Post
when you execute the "All Reset" button, will all the settings return to factory default? And will the profile setting be gone too?
Yes, everything goes back to factory default.
Old October 7th, 2008, 10:03 PM   #14
I had the exact same problem, resolved it 100% by turning off flicker reduction.
Jon Sands is offline   Reply With Quote
Old October 7th, 2008, 11:26 PM   #15
May it be you cellular phone? I noticed when the phone is checking the cell, it is buzzing into my computer speakers from 3 to 5 feet away. My old CRT monitor was doing same rolling flicker because of my cell phone.
I can not test it myself right now but I suggest to put your cell phone close to the camera while recording, ring the phone, and check the recording to see if it had any interference or not.
thx,
Mike
Mike Mona is offline   Reply
