Is the XDCAM-EX1 recording 1080progressive? - Page 2 at DVinfo.net
Old January 22nd, 2009, 03:05 AM   #16
Originally Posted by Mitchell Lewis View Post
So you've had good luck going from HD progressive to SD interlaced just making one trip to Compressor? Are your projects mostly just full-frame video or do they contain a lot of full-frame graphics/logos? That's what I've had problems with, graphics. I think it's because they have much sharper edges, they are harder for Compressor to transcode nicely. I thought I had tried everything (see the other 10 page thread) but maybe I haven't. You should share your process in detail on this thread:
http://www.dvinfo.net/conf/sony-xdca...-fcp-only.html
My downconversion to SD is through a Blackmagic Decklink Extreme card. It's in real-time.
The interlaced material is for the cable outlet's HD channel. It's 1080i.
If your graphics and titles are aliasing, then check the "properties" within the sequence and see if field order is set properly. For progressive it should be set to "none". For some reason the titler in FCP and Livetype will often set it to "upper" or "lower".
Good luck!
Dean Sensui
Dean Sensui is offline   Reply
