SDHC substitute for SxS cards - Page 42 at DVinfo.net
Old October 15th, 2008, 09:21 AM   #616
John: in my experience, when camera recognizes IOC combo, it works just fine.
It is however unpleasant to see the camera Not recognizing the combo sometimes. It will take a couple cycles of taking adapter out of cam and re-inserting it, or powering cam down then up again; for the combo to be recognized.
I would never recommend this kind of play during the live shoot; instead, allocate 2 minutes for this before the shoot.
It's more like, set it and forget it kind of thing - if you have a long shoot like an interview or a concert, just have the cam recognize the combo, and roll. I've never seen the combo fail *after* it was recognized by the cam. (Unless you power the cam down - then you'll have to repeat the procedure, or not - it's a crap shoot.)
After an hour (for 16Gb card capacity), provide a minute or two of downtime for changing the combos, in case the cam requires re-inserting them to be recognized.
Again: this does NOT look like an acceptable procedure to me if you were planning on changing the IOCxS combos live while camera was still recording.
Kensington adapter (that I do not own yet) apparently does not give this grief, albeit at 3x the IOC Buy'com's price (if you never even count the IOC rebate.)
Alex Raskin is offline   Reply With Quote
Old October 15th, 2008, 09:34 AM   #617
Originally Posted by Jon Braeley View Post
I am looking for a portable storage solution, ... I will have my Macbook Pro with me,
I can recommend Shotput software with 1 external USB hard drive - tiny one like WD Passport of capacity that you need.
Then just use Shotput to offload the footage to both your Mac's HDD and USB drive simultaneously.
Shotput also verifies the data, and you'll have your footage in 2 separate locations, which is virtually loss-proof.
I use this setup on location with PC-based Shotput, and am happy with the results. It takes just a bit longer to offload to 2 locations simultaneously, vs one location.
Old October 15th, 2008, 10:50 AM   #618
just got my Kensington 7-in-1 media reader and Sandisk Ultra 2 16GB SDHC card, pop it into EX1, nothing happened, EX1 not seeing the card reader. Took it out and pop it into my Sony Vaio, detected it as G drive, although my SDHC card is inserted it still asked me to 'insert a disk into removable drive'. Tried to do a format from my Vaio, it say 'no disk in drive G'
tried with my other Transcend 4GB SDHC class 6 card, same observation.
Damm , waited so long for my setup and this is the outcome. Do you think I got a faulty Kensington card?
John Woo is offline   Reply With Quote
Old October 15th, 2008, 11:04 AM   #619
Silly question but do you have the latest firmware ? V1.11.
I'm using transcend and kensington, not a single problem yet.
Paul.
Round 2
GH5,FZ2000
Old October 15th, 2008, 11:08 AM   #620
Yes, mine were upgraded to 1.11_0531
I have been following this thread from day 1 that's why I went ahead to buy the Keningston card reader.
Old October 15th, 2008, 11:12 AM   #621
Hmm... Maybe defective Kensington?
I own four that work fine.
Old October 15th, 2008, 11:14 AM   #622
Paul... is this the transcend card you use?
If yes, I'll order and test it with my IOC adapters for now...
Also, how long does it take you to offload the full card to your computer?
Old October 15th, 2008, 11:15 AM   #623
some guys have all the luck. not me :-(
I am sending back the card.
Old October 15th, 2008, 11:26 AM   #624
Yes that's the card i use.
With the usb reader it offloads about 4x speed, about the same as the sony sxs reader.
I buy my cards from an ebay shop which just happens to be about 1 mile from my house, so i don't actually buy them from ebay but i just wander in the shop and buy them.
The shop is called "shop4usb". I wouldn't usually advise anyone to buy memory cards from ebay but i can vouch for this shop/these cards, and the guys who run it, all genuine.
I pay £25 for the 16gb transcend or £30 with the included reader.
Paul.
Round 2
GH5,FZ2000
Old October 15th, 2008, 01:47 PM   #625
Originally Posted by Ted OMalley View Post
Paul and Stephen,
I'm using the SDHC solution in my EX3. My card is the Extreme III 16GB. I'm shooting 720 30p.
I played for about four hours yesterday with this solution and overcrank. I was NEVER able to get it to fail overcranked to 52 or less. At 54, it would error within 15 minutes. At 60, it would error within five or ten minutes.
I tried numerous short clips, long clips, etc. I was able to record overcranked to 52 without any issues, filling up my SD card twice (58 minutes each time!)
It seems I'm getting slightly better results than I've read. Is it the EX3? The SD Extreme III? My particular Kensington reader? I was going to purchase some Ultra II's, but I'm thinking about sticking with my current setup.
Do you have any ideas on how I can test this more rigorously?
I don't mean to sound impatient, but I think this may have gotten buried. Does anyone know why I'd be getting better results or how I can test more thoroughly?
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT
Ted OMalley is offline   Reply With Quote
Old October 15th, 2008, 02:53 PM   #626
My Kensington/ Extreme III 30MB/s SDHC will only over overcrank 24P at 45FPS. At 50FPS it fails.
If you're getting a bit more, I'm not sure why. But either way, with the ability to overcrank to 40FPS without an error, this info gives us a peace of mind that we can run HQ modes without an issue.
Old October 15th, 2008, 02:59 PM   #627
Sorry if you answered this before... what maximum fps rate can you overcrank your transcend 16gb card to in EX1 without errors?
(I'm getting very stable 40fps with my IOC/Sandisk Extreme III combo...)
Old October 15th, 2008, 03:22 PM   #628
At least at this point, I have a feeling we will not be able to get the full 60FPS overcrank regardless on what SDHC / expresscard combo.
Alister, has an expresscard reader in his PC that is capable of USB protocol.
He tested the Kensington/SDHC card (I can't remember which SDHC card), he was at over 15MB/s datarate. The same datarate seen using the SDHC card reader in his PC.
Overcranking 60FPS at 24P is approx. 12.5MB/s, so the bottleneck appears to be the EX.
Sony might of crippled the USB data transfer, or something or another.
Again, this may explain why their own PHU-60K (USB drive) barely runs HQ modes and will not work for overcrank.
Old October 15th, 2008, 03:32 PM   #629
Yes, I just want to see what headroom do we have with Transcend cards, which I personally have not tested yet.
Old October 15th, 2008, 04:07 PM   #630
Alex, I have both the Transcend 16GB and the Sandisk Ultra II 15MB/sec 16GB cards.
Here's my results:
Transcend: Reliable up to 38FPS at 720P
Sandisk Ultra II: Reliable up to 40FPS at 720P
I have a Mac program called XBench that benchmarks drives:
Transcend:
Disk Test 1.51
Sequential 17.28
Uncached Write 14.67 9.01 MB/sec [4K blocks]
Uncached Write 14.87 8.42 MB/sec [256K blocks]
Uncached Read 14.88 4.35 MB/sec [4K blocks]
Uncached Read 34.63 17.41 MB/sec [256K blocks]
Random 0.79
Uncached Write 0.21 0.02 MB/sec [4K blocks]
Uncached Write 3.73 1.20 MB/sec [256K blocks]
Uncached Read 500.69 3.55 MB/sec [4K blocks]
Uncached Read 92.84 17.23 MB/sec [256K blocks]
Sandisk Ultra:
Disk Test 1.81
Sequential 17.79
Uncached Write 15.44 9.48 MB/sec [4K blocks]
Uncached Write 22.12 12.52 MB/sec [256K blocks]
Uncached Read 11.73 3.43 MB/sec [4K blocks]
Uncached Read 33.67 16.92 MB/sec [256K blocks]
Random 0.95
Uncached Write 0.25 0.03 MB/sec [4K blocks]
Uncached Write 4.76 1.52 MB/sec [256K blocks]
Uncached Read 428.95 3.04 MB/sec [4K blocks]
Uncached Read 82.26 15.26 MB/sec [256K blocks]
Conclusion: Sandisk is a faster card and is 5% faster in the EX1 than the Transcend. I'm keeping my Ultra, I'll use it as the first go-to SDHC card (until I get my 32MB Ultra), then I'll use my Transcends if I need to.
Keith Moreau is offline   Reply
