How to see both zebra 1 AND 2? at DVinfo.net
Old September 12th, 2008, 01:56 PM   #1
Hi! Seems that I can't see zebra 2, just 1. And it's only possible to change the value for zebra 1. I just can't figure out how to see both 1 and 2.
Regards / Jimmy
Jimmy Alenius is offline   Reply With Quote
Old September 12th, 2008, 02:13 PM   #2
Images: 1
True, Zebra 1 is adjustable and Zebra 2 is fixed at 100. Zebra 1 will be a striped pattern. Zebra 2 on my F350 is a dot pattern and is harder to see.
-gb-
Old September 12th, 2008, 04:53 PM   #3
Regards / Jimmy
As Greg said, Zebra 1 can be changed but Zebra 2 is ALWAYS at 100IRE. The Zebra 2 stripes are thicker and are slanted the opposite way that Zebra 1's are.
See page 41 of the EX1 manual for a more detailed explanation and visual of the zebra-patterns.
Adam Reuter is offline   Reply With Quote
Old September 13th, 2008, 01:32 AM   #4
Regards / Jimmy
Make sure both zebras are selected in the menu.
You can select 1 or 2 or both.
Paul.
Round 2
GH5,FZ2000
Old September 13th, 2008, 02:41 AM   #5
Ok, I didn't got that the second zebra had a looked value. Thanks! But I have selected "both" in the zebra meny and still can't see thicker pattern for 100 and over. I point the camera right in to a light source and still can't see zebra 2 even when using the smalles f-stop. Is the filming on the sun the only thing that push the camera over 100?
Regards / Jimmy
Old September 13th, 2008, 08:52 AM   #6
check this...
Regards / Jimmy
If both zebras are selected in the menu, and the iris is open while pointing at a bright light... toggle the external zebra button on the camera and that should do it. The placement of this button on the ex1/3 are located in different places if i remember correctly.
Greg
Greg Chisholm is offline   Reply With Quote
Old September 13th, 2008, 09:11 AM   #7
Images: 1
Make sure you aren't in an auto exposure mode which will alter the iris and/or shutter to keep exposure down below 100.
-gb-
Old September 13th, 2008, 11:57 AM   #8
Also, make sure that you aren't using a Picture Profile that rolls off the highlights too much.
Dave Morrison is offline   Reply
