SxS vs SDI (comparison) - Page 2 at DVinfo.net
Old September 11th, 2008, 07:13 AM   #16
Originally Posted by Bill Spence View Post
Also, notice the dynamic range. I don't know if SDI bypasses the gama curves, but if you look at the side of the car in the SDI photo, it is much brighter and a lot more detail available around the wheel than on the MPEG picture. You see the same thing around the rusty bolts at the base of the column - you can see into the shadows there better in the SDI picture.
That would be the 10 bit quantisation of HD-SDI vs the 8 bit of MPEG2. 1024 levels vs 256. It doesn't bypass the gamma circuits, the HD-SDI signal can just carry more of the original information. I think the CMOS chip outputs 14 bit, which is 16384 levels, which gets averaged down to 1024 or 256.
David C. Williams is offline   Reply With Quote
Old September 12th, 2008, 09:00 AM   #17
I didn't have enough time to make more footage (i will i promise) but may be this is an approximation to the definitive answer. make this:
download both images. One comes from the SxS in 8 bits and the other from the SDI in 10 bits and both images are PNGs 16 bits so there is no doubt about how many colors the files can handle.
Make a levels adjustment layer in every picture. Looking at the histogram you already see the differences, the SxS have a lot of white bands (areas that has no information).
Now let push things really far: make a severe levels adjustment like 80 1 160.
What do you see? yep, the SxS image have a lot of banding (even if this image is not the best to judge banding since it doesnt have a big area with a soft chroma or luma transition but anyway you can see the banding) and noise (imagine that noise in the moving image, i mean, the noise moving from frame to frame, Ughhh!!)
Now turn off the levels adjustment layer and make a new adjustment layer with Hue/Saturation, turn the saturation up to, lets say, 70. What do you see? the SxS image have a lot of color noise and banding too.
I know, you will say, "I seldom have to make so severe color correction" but take your time and play a little with the pics and you will see that in many cases an enhancement in contrast is enough to show a big difference between the images. In the other hand many times you want to attain a look that needs severe color correction (and not this useless levels and saturation test).
if you are unsure because of the difference in brightness go to match colors on the SxS file and match to the SDI and then make the tests (donīt make the opposite since the SDI have more info and you will downgrade the image)
if you have enough patience try this: duplicate the image layer, on the top layer put a high-pass filter with a radius of 3 pixels (you can use another value if you like), set the blending mode of this layer to overlay. I used this technique many times to sharpen an image without introducing too much noise, then you can play with the opacity of the layer to set the amount of sharpness that you like or even mask out the areas where you donīt like to have the sharpness. as you can see on the SxS image the noise is sharpened as well (in fact in both images the noise is sharpened but the SDI image have less noise). Again, if you donīt plan to make strong corrections to your footage the visual difference is not really too much to make it worth to work in uncompressed, sdi, etc, otherwise...
Also consider that many times to make some types of looks you will be doing in several passes, even with several different softwares and each pass will show more and more the limitations of the compressed video.
Now if you have access to a color grading package like Apple Color or Autodesk Lustre, or whatever, open both images and try to qualify for a secondary. As you can guess the SxS is much more difficult to qualify. So many times you will find yourself making masks to be able to make secondary color corrections. In this particular image this issue is not big deal but, what happens when your camera is moving (with changes on perspectives) and character passing in front of the object or area you want to make that secondary CC? it could be a nightmare.
Thatīs why a device like the nanoflash is more than welcome for me. The only thing I wonder is: since 4:2:2 footage takes much more space than 4:2:0, would it be 100mb/s 4:2:2 much less compressed than 35mb/s in 4:2:0? no answer so far, i have to take a closer look to the numbers.
Martin Chab is offline   Reply With Quote
Old September 12th, 2008, 06:45 PM   #18
I've calculated that a 4:2:2 image holds 20% more raw information than a 4:2:0 image of the same. You can't really say then though from that, that you need a 20% higher compression rate to maintain the same fidelity. Compression is a very complex thing as you know I'm sure. It would change from image to image, but likely less than 20% extra on average I'd think.
The colour fidelity of 4:2:2 is a large leap from 4:2:0 though, with one out of two pixels the correct colour, rather than a block of four averaged to "almost" correct.
It's a pity Sony are so bent on protecting their high end market, as this camera could easily have recorded 4:2:2 to SxS natively at no greater cost.
Old September 13th, 2008, 12:32 AM   #19
I agree, so for a little extra hardware cost, I will be able to 4:2:2 record from my EX3 onto my upcoming nanoflash. Looking forward to that in the next couple of months or so.
After the XDR & NF are out, Sony will need to rethink their 4:2:2 pricing, just as you have suggested. An EX5??? upgrade maybe???
Cheers
David Issko
David Issko
Edit 1 Video Productions
David Issko is offline   Reply
