Highlights get washed out - the gamma curve? - Page 2 at DVinfo.net
Old September 8th, 2008, 04:16 PM   #16
Just as a reality check here:
Cine 4 may work great for some people, but its hardly neccessary to get good exposure , and neither are Bill Raven's matrix settings neccessary though again people may find them lovely.
However, it is perfectly fine to use a normal gamma like Std 3, simply drop the black level to -6 (where it belongs to get black) and put the saturation level where you find it pleasing - probably raising it to hi sat. That's enough to get very good pictures with this camera. There is nothing wrong with those basic settings.
That's not to say you can't improve on it. I have changed those settings myself, but they really do produce very good pictures.
Lenny Levy
Thanks, Lenny. I've been trying several different settings to see which ones suit me. This camera is truly amazing!
Forrest
Forrest Burger is offline   Reply With Quote
Old September 8th, 2008, 06:50 PM   #17
Dropping the black to -6 gets you to where black should be? That is new info to me, but sort of correlates to what I've noticed (I've been setting it to -5). I've only had my EX1 for a short time but always felt the black levels were too high at 0. Did you check this with a scope? Also is this with any of the gamma settings or just the STD ones?
Paul Frederick is offline   Reply With Quote
Old September 8th, 2008, 10:13 PM   #18
Yes - its the first thing I check with a new camera because its so often off - similar with an HVX. I don't know why they send cameras out that way.
I have been using STD3 so its definitely accurate for the standard gammas. I think it was about right for the cine's but I wouldn't swear by that at all.
Lenny
Old September 9th, 2008, 02:34 AM   #19
I was using the cine's but now use std gamam's. I found that the cine's took too much light.
I now use std 1 with hi-sat, black at -5, detail -10.
Paul.
Round 2
GH5,FZ2000
Old September 9th, 2008, 05:31 AM   #20
Good to know about the -6 on black. I agree it should be lowered. Things look a bit washed out to me at 0. I find the Cine settings tend to soften highlight clipping. Especially on strong colors. I also have a PP with STD 3 for indoor situations, because I also find the cines eat up light somewhat, actually its applying an "s" curve to the highlights, gradually clipping them instead of the hard clip of the STDs.
Old September 9th, 2008, 06:23 AM   #21
Images: 3
I'm not sure that gradually clipping is quite what you mean. Clipping occurs at 109 and gradual it isn't. The cine gamma compress the highlights (the gamma curve rolls off) and applying +gamma to cine4 will roll the curve off so it never reaches 109 (makes for very flat highlights, without any clipping). But, other than this quibble, agree with your comments.
Old September 9th, 2008, 06:45 AM   #22
This is directly from Adam Wilts review on ProVideo Coalition.com: Pro Cameras, Video Editing, Motion Graphics
At the bottom he says "With Cine Gammas the highlights won't clip AS HARSHLY. Meaning they still clip, but not as severely.
"The EX1 offers four STD gammas and four CINE gammas. STD3 is the default and is the basis for my comparisons; I list the brightness for the middle gray on a chip chart in each gamma for the same exposure setting, with 50% being the default. The descriptions in quotes are my own characterizations of the gammas. In all except CINE2, whites peak at 109%.
• STD1 – “bright and contrasty”. Blacks slightly crushed, whites slightly crushed, increased contrast, midgray at 55%.
• STD2 – “deep blacks”. Blacks slightly crushed, rest of tonal scale stretched downward; midgray at 48%.
• STD3 – “standard video”. Normal, midgray at 50%.
• STD4 – “black stretch”. Blacks slightly stretched, increased shadow detail, midgray at 55%.
• CINE1 – “deep cine”. Compression starts around 80%; midgray at 37%.
• CINE2 – “broadcast safe cine”. CINE1 rescaled with whites limited to 100%.
• CINE3 – “brighter cine”. Compression starts around 65%; midgray at 45%.
• CINE4 – “video-bright cine”. Compression starts around 65%; midgray at 50%.
The std gammas are all fairly standard video gammas, while the cine gammas are something special. Instead of running linearly up the tonal scale and using the knee system to handle highlights, cine gammas apply increasingly more compression the brighter a highlight gets. Sony’s Juan Martinez says the cine gammas are directly descended from the HyperGamma settings of the F900/R and F23 cameras; David Leitner reports that these are the same HyperGammas used in the PDW series XDCAM HD camcorders.
In essence, cine gammas have a S-curve in the highlights, similar in effect to the soft shoulder of film’s DlogE curve. Highlights don’t clip as harshly as in the standard gammas, they roll off much more smoothly, with gradual desaturation instead of sudden hue shifts in color."
Old September 9th, 2008, 06:57 PM   #23
I have to say, this is one of the best threads yet on EX1 PP settings. By accident I shot an outdoor gardent interview yesterday with PP off. I had a new assistant who didn't catch it, and while out of the box the picture is pretty good, it's not until you start tweaking that you really see the magic of this camera. Now I've got a bit of post to get this to look right. It's nice to see what others are using. Thanks for the suggestions.
Mick Haensler
Higher Ground Media
Mick Haensler is offline   Reply With Quote
Old September 9th, 2008, 07:10 PM   #24
Using the Cine 4 gamma I'm able to retain detail in the tops of bright cumulus clouds while still retaining detail in faces below the brims of baseball caps.
With other video cameras that shadow detail is lost.
The black point isn't as low as it could get, but it provides me the option of either crushing the blacks in post or keeping as much detail as practical in the final product. Since I can't control the lighting in 99% of what I shoot, I opt for maximum dynamic range.
And as mentioned elsewhere in this thread, having the highlights gently preserved allows me to make shots look as good as possible in the final product. White shirts, bright clouds and even sunlight glinting off the water aren't troublesome at all.
Dean Sensui
Old October 4th, 2008, 10:42 PM   #25
Hi-
I don't know if this has any relationship to the problems you are having. There is apparently some issue with the gamma knees in the EX1/EX3 when using the standard gammas. Please read page 3 of Adam Wilt's review:
ProVideo Coalition.com: Camera Log by Adam Wilt | Founder | Pro Cameras, HDV Camera, HD Camera, Sony, Panasonic, JVC, RED, Video Camera Reviews
"when a highlight has a strong chroma component, the knee shuts off prematurely, allowing colored highlights to suddenly blow out."
The cine gamma are not affected by this.
Craig
Craig Mieritz is offline   Reply With Quote
Old October 16th, 2008, 02:09 PM   #26
Dean care to share you Cine4 preset? I enjoyed your show and would be interested in trying your preset.
Paul Cronin
www.paulcroninstudios.com
Old October 17th, 2008, 12:29 AM   #27
Paul...
Happy to hear you enjoyed what you saw.
It's just the standard Cine 4 gamma setting that comes with the camera. I didn't tweak it at all. I just make sure the historgram shows the entire exposure range is being captured.
Dean Sensui
Old October 17th, 2008, 06:57 AM   #28
Images: 10
One of the misconceptions with using a standard histogram to decide exposure is that you can still blow out one of the R-G-B channels and the single channel B&W histogram will tell you you're OK.
Shooting HDV, after a while you'll learn how to avoid thos hot spots. Using zebra set to 90% helps. The zebra on the EX1 can be off by as much as 10%.
Old October 17th, 2008, 08:43 AM   #29
Although I shoot with the EX3, I second what Bill has said. With every digital video camera I've ever used, I've set the zebra at either 90 or 95% (depending on the camera). That way, I can practically guarantee that burned out whites are a thing of the past.
Jay Gladwell is offline   Reply With Quote
Old October 17th, 2008, 10:15 AM   #30
...and take noise. ;)
Btw, that's true for cine1-3, but not for cine4, because it's "video-bright", meaning that its slope on the lower end is identical to that of the stds.
Dominik Seibold is offline   Reply
