Clipbrowser artifacts at DVinfo.net
Old September 3rd, 2008, 09:28 AM   #1
Yesterday I got my EX3. Quite happy! I checked the downloaded ClipBrowser 2.0 and I noticed artifacts in Avid Liquids. I checked different parametres but no solution. Today I decided to install the version 1.01. that came on CD with the cam. Less conversion options but superb results. Does anybody had similar experiences?
Markus
Freelance full service reporter
www.boehnisch.de
Markus Bo is offline   Reply With Quote
Old September 3rd, 2008, 01:18 PM   #2
Markus
Can you supply some details please. Like what format you exported in etc...
Ola Christoffersson is offline   Reply With Quote
Old September 3rd, 2008, 01:23 PM   #3
I just put it in MXF and I got those results without changing any parameters. And as I said, with the older version of CB no problem.
www.boehnisch.de
Old September 3rd, 2008, 01:29 PM   #4
That sounds very hard to believe. MXF-export does not change the file contents at all. It only rewrapps the MP4-wrapped media into an MXF-wrapper. It should theoretically not be able to affect picture quality. What kind of artifacts are you experiencing?
Old September 3rd, 2008, 01:42 PM   #5
Well, even harder to believe after resolving the problem with installing 1.0. The artifacts are squares (movements) or lines (panning).
Markus
www.boehnisch.de
Old September 3rd, 2008, 01:47 PM   #6
Markus
That sounds like the digital "drop outs" that you can get when error correction cannot keep up with a data stream missing data. Does it look like bad DVB-T reception? No problems with harddrives during all this?
Old September 3rd, 2008, 01:50 PM   #7
Harddrive or any other bottle neck were an option but I decided to export the clip to MPEG2 SD and the artifacts were still there, using VLC.
www.boehnisch.de
