Lens control connector of EX3 at DVinfo.net
Old August 16th, 2008, 12:27 PM   #1
i was looking the adaptor for 1/2 lenses, but where is the 12-pin lens control connector?
http://images.video.free.fr/Test-Z7/Lens.jpg
Marlon Martins is offline   Reply With Quote
Old August 16th, 2008, 01:06 PM   #2
The lens remote connector is already on the stock lens, or will be on the lens you are going to buy.
Ivan Snoeckx is offline   Reply With Quote
Old August 16th, 2008, 02:27 PM   #3
The EX3 lens mount uses a hot shoe connection, so the connection is via pins built in to the lens mount. The EX3 mount to Sony 1/2" adapter supplied with the camera also has a hot shoe so no cable is needed if using a Sony mount 1/2" lens. The current issue is that while you can get 1/2" to 2/3" adapters there is no simple way to get iris data and power to a 2/3" lens, as a result you can only use 2/3" lenses manually. Fujinon are bringing out an EX3 to 2/3" B4 adapter that will include a standard 12 pin lens control socket, transferring the connection from the EX3 hot shoe to the socket.
Old August 17th, 2008, 12:58 AM   #4
tnks guys. solved my doubts
Old August 17th, 2008, 03:45 AM   #5
From what I have been told by my Sony dealer, this adapter will cost a pretty packet - in the thousands.
I'll stick to my XS17x lens.
Cheers
David Issko
David Issko
Edit 1 Video Productions
David Issko is offline   Reply With Quote
Old August 17th, 2008, 09:02 AM   #6
I agree, I doubt it will be cheap. It wouldn't surprise me to see some 3rd party adapters.
Alister Chapman is offline   Reply
