EX3's Black Balance, and the IR contamination problem - Page 2 at DVinfo.net
Old August 24th, 2008, 09:46 AM   #16
Originally Posted by Adam Reuter View Post
The EX1 does have black balance. I believe it's in the maintenance menu.
Yes it it there, but isn't active (grayed out) - at least with the 1.02 fw I still have.
Old August 25th, 2008, 11:22 AM   #17
Sponsor: Schneider Optics
Originally Posted by Robert St-Onge View Post
Ryan, will the IR 750 filter be available in circular threaded: 77mm, 52mm and other diameters?
If so, when can we expect to purchase them?
Robert,
We can make almost any common filter size of the True-Cut IR 750. We have a few 77mm sizes in-stock and will likely make those a regular limited stock item. The other sizes will be special order with an average 3 to 4 weeks lead time. You may contact your favorite dvinfo.net sponsor dealer, tell them the filter and size you want, and we will work together to get you a price.
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old August 25th, 2008, 01:04 PM   #18
Ned, have you tested the IR750 under tungstun?
Old August 25th, 2008, 01:32 PM   #19
Originally Posted by Alex Raskin View Post
Is infrared light polarized?
Polarization isn't a property of special wavelengths. Most surfaces reflect diffuse, so they destroy any polarization, if there was any. Transparent stuff like glass is reflecting purely linear-polarized, if the light hits it with the brewster-angle of incidence.
Dominik Seibold is offline   Reply With Quote
Old August 25th, 2008, 01:50 PM   #20
Dominik, then do I understand correctly that Polarizers block light more or less evenly throughout both visible and IR spectrum, and therefore do not work as IR blockers?
Alex Raskin is offline   Reply With Quote
Old August 25th, 2008, 01:53 PM   #21
Not yet.
High priority this week is IR750 testing.
Ned
Ned Soltz is offline   Reply With Quote
Old August 25th, 2008, 08:21 PM   #22
That's correct.
Old August 29th, 2008, 08:52 AM   #23
Originally Posted by Dominik Seibold View Post
That's correct.
Ditto that.
Ryan Avery
Schneider Optics
Old September 5th, 2009, 05:36 AM   #24
Hi,
FYI I have a new EX3 with firmware 1.04-0084 and yes the IR problem is still there Sony really sucks on this one.
I have tried black balance, white balance and black balance again and it has not fixed the problem. I have just ordered a Tiffen 4 x 4 IR (IR680) due in 3 weeks to try to fix the problem. Most of my work is under QI lights. I had to do a interview yesterday and decided to not to use the Blonds and Redhead instead I use some new high intensity 2300K LED lights for the shoot. The images were great no IR contamination black were solid and crisp.
That’s great for close up work my problem is I do a lot of stage and musical productions that I have no control over lighting.
I would also be very interested in any tests using IR filters if some can post results.
Lance Librandi is offline   Reply With Quote
Old September 5th, 2009, 07:23 AM   #25
Please report how your 680 is doing, preferably post some grabs!
TIA,
Piotr
Old September 5th, 2009, 10:37 AM   #26
my ir problem dissapeared when i used the b&w 486 filter.
Dano
Dano Motley is offline   Reply With Quote
Old September 5th, 2009, 10:51 AM   #27
Dano
Same here.
Also, the amount of IR which is allowed to hit the sensors is determined by a fixed hi-pass filter which is permanently attached to the CMOS sensor assembly inside the camera. I wouldn't have expected a firmware update to alter that. Many CMOS-based cameras exhibit this behavior. If you want to see an extreme example, Google "Leica M8 IR contamination" - it will make you feel better about your EX1/EX3. (If "Sony sucks on this" then so does RED, Canon, ...)
I frequently shoot under hot lights and the 486 filter lets me control how far down the spectrum to go.
Brooks Graham is offline   Reply With Quote
Old September 6th, 2009, 05:26 AM   #28
Dano
Same here as well.
Anthony McErlean is offline   Reply
