Thread Tools
Search this Thread
EX1 as audio recording device, how´s that working for you?
Hi all!
So far I´ve only been shooting with my EX1 in non sync-sound situations, so if recording audio at all, I´ve only used the internal mics for "reference" sound. I have some projects coming up that requires sync sound and will use a few different mics (ME66, Senn lav wireless & Oktava 102 Hypercardioid and no, not all at once, but these are those I have to work with) going through a field mixer (Mixpre) and into the EX1. For the next 2 weeks I have let a friend use the EX1 so I can´t run any tests with it, hence my question; What´s the verdict on the EX1 as an audio recording device? Audio will reach camera at line level, does anyone know of any problems with this setup? does audio recorded in a proper way sound "good" or "right" on the EX1?? Magnus |
I shoot weddings, using 2 wireless mics, and a 416, and have been very pleased with the sound quality.
#3 | |
Firstly: be very VERY aware that low frequency sounds (bass bins, wind noise, anything deep and loud) will make an awful tinkling noise on your audio. But if you use Bass Cut, it cuts too much bass. Keep out of the wind, fluff up your dead-cat, don't try to record in night clubs. Secondly: there's a limiter in the audio channels. It will dip loud signals in the voice range and above, but not in the nice gentle way that the Z1 did. It will whack those loud bits down with a right-hander to their upper cheeks. So, watch that dynamic range, don't mic too close, don't over-drive the levels. Thirdly: there's no 'line' and 'mic' settings in the input levels, just a long reel of negative numbers. I can't list any magic numbers for you, just test it out. This is what bakes my noodle and drives me bonkers. But Finally - most important: the audio level controls are attached to the actual level controls by knicker-elastic. Twiddle a knob and it can take SECONDS for the audio level to respond. Ye gods, we'd be better off by semaphore. Heck, even Guzzi throttles were more responsive. Think Volvo Turbo lag. Wind up the level, wait, wait, and anticipate.... and THERE! Seconds later, you have the level you dialed. Arrgh - just give me one hour alone with the EX1 design team in a sound proofed room and a stirrup pump.
Director/Editor - MDMA Ltd: Write, Shoot, Edit, Publish - mattdavis.pro EX1 x2, C100 --> FCPX & PPro6 |
Matt,
Great Post! Do you know if any of these things have been addressed in the EX3? |
#5 |
Thanks for a great answer Matt! Just the kind of info I was after, will test it out when I get my camera back, thanks again!!
Magnus PS. Sorry to hear about your noodle, having had my own baked a few times, I know how you must feel... |
#6 | |
Kino-Eye
Matt's advice is spot on, I would add one thing, it's still a good idea with this camera (as with most cameras) to use a professional mixer and feed the camera line level whenever possible, you get 1. a more gentle limiter, 2. better microphone preamps, 3. the ergonomics of mixer knobs and a nice visual display, and 4. more versatile monitoring options. That said, I often have to shoot solo doc style and I have not choice but to set the camera on auto audio and go with whatever I can get, but when I do formal interviews, or shoot narrative style, I use my mixer whenever I can and even sometimes do double system (a whole other story).
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye } |
#7 |
I like it
This is one of my favorite things on the EX. I like the way it sounds. I use a Rode NTG-2 right on the cam shock mount when the shoe is needed and the audio seems crystal to me.
Admittedly I don't come from an audio background so what sounds good to me may sound not so good to "trained" ears, but I know it has really been an improvement over the same mic on the Z1..... this is my experience... hope it helps. |
#8 |
i got this low freq humming sound in a room which had a fan on! I have no idea what I could have done to get rid of picking it up with the ME66. Should i have turned on the rollover?
#9 |
The rollover (or LF Cut) takes out quite a lot of bass response, and is overkill to get rid of something like fan hum.
Much better to use noise reduction processes in a dedicated audio program like Soundforge or Adobe Audtion, or at the very least use a graphic equalizer when you can find the specific frequency where the hum is and reduce it 12 db or so by winding back the gain at that frequency. Cheers Vaughan |
