How do I output audio when using component out? at DVinfo.net
Old July 19th, 2008, 12:15 PM   #1
I added this question to the end of another thread, but didn't get an answer so I thought I would create a separate thread for the question.
I wan't to be able to show clips from the camera on an HDTV or through my digital projector and sound system.
According to the manual, if I output from the camera in HD via component video to a display capable of displaying 720 or 1080 (my video projector), the A/V composite output is disabled.
Where do I get the audio from?
John
John Peterson is offline   Reply With Quote
Old July 19th, 2008, 12:18 PM   #2
when i hooked my camera up to my 40" sony lcd i used component video cables + audio ends from composite cable and it worked fine.
Sony EX1 v1.11, crap loads of SxS, Macs w/ Final Cut Studio
Andrew Hollister is offline   Reply With Quote
Old July 19th, 2008, 12:30 PM   #3
Thanks for the clarification. I guess then, the translation of the Sony manual on page 117 on the chart entitled "Limitations of Outputs" should be:
For a Menu setting of YPbPr/SDI Out Select to HD. A/V OUT should read No (video) signal instead of No signal or Audio only instead of No signal.
Thanks again,
John
Old July 20th, 2008, 04:09 PM   #4
Update:
It works just fine. Analog Audio on the A/V output is indeed active in conjunction with using Component Out despite what the manual says.
I would assume that also applies to SDI out as well, but I have nothing to test that output with right now to confirm.
John
