#16 |
This is indeed a nasty surprise, Paul! Have been trying all my MPEG players, and only Nero Showtime tries to play the mxf's back - but it has a tendency to hang ...
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#17 |
This version still won't play the files in the preview window consecutively. You have to play them one at a time. I don't get it.
In terms of VLC media player playing the MXF files, just change the extension to either .m2v or even to .mpg and it will play them. If you put all of them in a single directory, you can open that directory in VLC media player and it will play them all consecutively. John |
#18 | |
OK - the 0.8.6d DOES play mxf's even without renaming (still no sound though).
#19 | |
John |
#20 | |
But you know what? I changed the interface language from default (Polish in my case) to US-eng, and voila! - VLC does play mxf's with sound, both those from the previoues and the latest ClipBrowser versions.
#21 |
#22 | |
You're right though that when CREATING separate video and audio streams (like at NLE rendering), the m2v (video) stream file name (main part) must be the same for its audio (whichever format) counterpart, for many players to play the 2 simultaneously.
#23 |
Hopefully, sometime soon, vegas will be able to use the raw files so i won't bother rewrapping, i'll just copy the files to my hard-drive then check they're all there with clip browser, then delete the card with clip browser. If i need to rewrap to mxf for someone else,i'll just use vegas to check that the transfer was succesful.
So, i don't need anything except vegas and clip browser. Paul
Round 2 GH5,FZ2000 |
#24 |
#25 |
http://www.mainconcept.com/site/index.php?id=21901
The link is in the pdf manual you can download from the same page as the ClipBrowser software.
#26 |
Don't we have most of the watermarked main concept codecs included in Vegas Pro 8.0b now? Would there be some advantage to converting these with Clip Browser 2.0 instead of Vegas?
#27 | |
Just compare the time needed! Of course, we usually edit, and do at least one final render anyway, but sometimes you would need another format quickly - perhaps to hand over to the customer?
#28 | |
How does the XDCAM SQ transcode from HQ look? Never mind...I should just try some of these things and not bother everybody. |
#29 |
Tom,
I really don't know how they do it, but exporting to all those format added to ClipBrowser v2 is almost as quick as re-wrapping to mxf with v1. Really, just like re-wrapping - not rendering! Oh, and SD down-conversion (no watermark - pure DV AVI) is very good, IMHO (will not swear just yet it's better than my DVD renders with Vegas, but it's certainly much quicker)...
#30 |
BTW, ClipBrowser 2.0 is now also available for download from the http://sonybiz.net European site.
