Audio Suddenly out of Sync - FCP & EX-1 at DVinfo.net
Old July 15th, 2008, 01:06 PM   #1
Have many EX-1 projects going, all was fine. I may have accidentally changed something.
No matter where I put the play head, audio is in sync for a second, then falls out. Could it be a sequence setting?
L.J. Morelli is offline   Reply With Quote
Old July 15th, 2008, 01:57 PM   #2
There's nothing inherently wrong with EX and sync so you must have done something but there's no way anyone here can guess.
Create a new project using EX easy setup and put your files in there. Create a NEW sequence and see what happens.
Old July 15th, 2008, 02:27 PM   #3
Originally Posted by L.J. Morelli View Post
Have many EX-1 projects going . . . No matter where I put the play head, audio is in sync for a second, then falls out.
Does this happen on all your sequences, or just one in particular?
I taught you all I know and still you know nothing.
Andy Nickless is offline   Reply With Quote
Old July 18th, 2008, 11:59 PM   #4
What is EX easy set up? And, yes, it happens on all sequences.
Old July 19th, 2008, 12:35 AM   #5
This problem must be very frustrating indeed. I know because I had a very similar experience with the Panasonic HVX200. FCP didn't fully support the format I was using.
The good thing about it was it prompted me to change to the EX1 and that was an excellent move.
Unfortunately, people can't answer your question if you don't provide information for them to trace the problem from.
What editing system are you using?
What system version (and has it been updated recently)?
Are the sequences that you say were previously in sync, now going out of sync?
What format are you shooting?
What format are your timelines?
(In FCP you should use Easy Setup to make the project the same as the format your footage was shot in, then open a NEW sequence and drop the clips in there).
Lastly, what is your exact workflow?
Old July 20th, 2008, 08:39 PM   #6
Got it, used EASY SET UP, and chose XDCAM EX 1080i60 VBR. Can someone confirm if this is correct? Material was shot in 1080i60. The pull down menu was on something else I can't remember now.
Old July 21st, 2008, 12:46 AM   #7
Sounds right but I'm in PAL territory, so I can't be certain.
Is the audio back in sync now?
Old July 21st, 2008, 10:42 PM   #8
Yes, most definitely. Thanks for the good advice.
